oil change ?
Old Mar 25, 2004 | 05:27 AM
350black's Avatar
350black
Default oil change ?
I use mobil 1 5w-30. I was told that when using this synthetic I should only be changing the oil every 6000 miles instead of the usual 3000 miles. Anyone on here have any opinion on this?
Old Mar 25, 2004 | 07:11 AM
yobri's Avatar
yobri
There aren't many on the board that'll exceed 5K between changes even with synthetic. Other automotive boards swear by 10-15K oil change intervals... I guess it's really a matter of preference and what offers you the best peace-of-mind. How hard you drive really can affect when you should perform a change though.
Old Mar 25, 2004 | 07:21 AM
gooters's Avatar
gooters
Good point ^.
If you arent racing and stuff, 5 or 6K is fine on Mobil1, imo.
Just check your oil every grand or so, to be super safe.
Old Mar 25, 2004 | 07:22 AM
gooters's Avatar
gooters
BTW...do you guys "prime" your oil filter? I have always done this, but a tech at the place I get my oil changed told me this wasnt beneficial really unless you were running a turbo...any thoughts?
Old Mar 25, 2004 | 07:25 AM
tiswicked's Avatar
tiswicked
What do you mean by "prime" you oil filter? I am not too familiar with that term.
Old Mar 25, 2004 | 07:35 AM
yobri's Avatar
yobri
Putting some oil (less than a quart or so) into the filter before applying it to the engine. [I believe] most oil changes are done with the filter dry, but with the typical lubed gasket.
Old Mar 25, 2004 | 07:52 AM
Sly_Z's Avatar
Sly_Z
I heard that synthetic isn't good for our cars. You sould look into it, before you continue using it.
Old Mar 25, 2004 | 09:48 AM
350black's Avatar
350black
Sly, mobil 1 is about the best that you can put into your Z. I called Nissan before using it and they said that if you can afford it put it in, it is the best for the V6.
Old Mar 25, 2004 | 05:08 PM
myehrick09's Avatar
myehrick09
Right now, i am using Valvoline synthetic. but a friend of mine who's a mechanic @ a Honda dealerstore told me that the best oil out there now is the Mobile 1 Syn. He also mentioned that if you are usisng synthetic oils, you really dont have to change it until 5000k(only if your'e not flooring it all the time!)
Old Mar 25, 2004 | 06:28 PM
zuddenly's Avatar
zuddenly
using mobil 1 5w30 as well... change roughly around 3k... depends how much you baby your car i guess.
just gotta remember, altho the oil is synthetic, additives do wear out just the same... and that's why i change at 3k.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
