Greddy evoII exhaust trouble?
on
I got the exhaust installed 2 days ago and today the "service engine soon" light came on. I took it back to the place where i got it installed and they double checked everything even with greddy and said everything was and is done proper. They said to just disconnect the battery to restart the sensor and see if it comes back on. The gas cap was not loose but i did add some octane boost to my fill up if that could have anything to do with it? If anyone knows anything about my problem replies will be greatly appretiated!
on
never heard anything like that from Greddy exhaust.
Octane boost might have something to do with it.
just wait till you use up all the gas that is mix with octane boost and see what's going on.
on
Hey, I have had the GReddy EVO2 installed on my '04 Track for a few months now, and my SES light has come on twice. I took the car to the dealership to have the code pulled, and it was for a "Gross EVAP leak". The EVAP system is that black box that got moved to the center of the vehicle to make room for the right muffler. There are two black solid metal pipes about 3/4" in diameter that come from the front of car and are connected via rubber tubing to the EVAP unit. Right at the end of those black metal pipes, they bend about 30 degrees to the right to make a straight shot to the stock location of the EVAP unit. The problem I had was that the with the new location of the EVAP unit, the rubber tubing has to make a 180 degree bend to loop around to the fittings on the EVAP box. The smaller of the rubber tubes provided by GReddy is about 1.5 to 2 inches too short, so when you push it onto the metal tube at one end and the EVAP box fitting on the other, it "kinked" in the middle just a bit. I think this restriction appears to the "flow sensor" in the EVAP box as if the system isn't getting as much flow as it should, so it registers a leak. Also, I had to bend one of the metal tubes up toward the trunk pan about 1/2 inch to get it clear of the muffler. It was pressing really hard against the muffler otherwise. This was very difficult because the tubes are quite rigid. I don't think this contributed to the SES light, but it was a fitment problem nonetheless. Also, make sure all of your clamps are in place and tight, and that none of the plastic fittings on the EVAP housing are cracked. Also, and I know it sounds silly, but make sure the rubber tubes are connected properly..If you have them backwards, that'll cause problems for sure.
If your dealership is cool, they'll probably pull the code for you at no cost. Go from there.....Good luck!
on
hey bro i got everything rechecked and they said everything looked fine so they just told me to get new gas and then unhook the battery. I did all of that and got the light to go off and then a day later it came back on. so now i know it is the exhaust. What exactly did you have to do to your hoses to get them right?
Sleeps in 350Z
on
A bit off topic, but on the evap unit, are your hoses firmly up against the exhaust?
Mine are wrapped in heat shielding, but I'm wondering if that's enough. The hoses are directly against the canister.
i'm just afraid to go to the dealer because im not sure if they are cool with mods or not!
If it turns out to be the EVAP system, then it's arguable whether that's exhaust related or not, really. You didn't "modify" the evap system, all you did was relocate the canister and re-reroute the plumbing.
Either way, you need to know what error the ECU is seeing so you know where to look. All of the exhaust components come after the O2 sensors, so it's not like they can say your exhaust system caused a problem with that.
And look at it this way, you're not going to get any support from GReddy on this until you have more information (i.e. what's the code)
on
my SES light came on shortly after installing the EVO2. installers tried to disconnect the battery, but its still on. i'm sure the SES light is related to the exhaust/EVAP. i'll probably try to rearrange the tubes myself. not sure the EVO2 is the best designed exhaust as mine is not aligned properly either. you'd expect better from GReddy especially for a $1000 exhaust...
Sleeps in 350Z
on
I've only had my exhaust on for a week and have only driven it a handful of times. My SES light ahs not yet come on (knock on wood).
How soon did this happen to you guys? Was it immediate or did it take a while to happen?
MDubbsZ, just curious, but where did you get your exhaust installed? I'm in the bay too.
on
my exhaust looks great and the light came on after the second day. By the way i just got back from the dealer and the scanner read a small leak. he put the car on the lift and all the tubes looked unrestricted but the connector from the bigger tube to the evap box wiggles a little. the mechanic said it is supposed to be firm and air tight and it seems to be loose. so he reset the light and if it comes back on im going to replace the connector and see what happens.
on
i took my car to the dealer to get it scanned and believe it or not it reads a small exhaust leak. the guy put it on the lift and there is a cylindrical plastic tube which at one end holds a sensor and at the other end connects to a tube. The piece then connects to the evap box. the guy said he could wiggle the piece and said it should be firm and air tight. so im trying to get the installer to pay for the piece and the scan. the whole deal is really pissing me off after spending $1100 just to make trouble!
Is it reading an exhaust leak or an EVAP leak? I don't think there is a way for the ECU to detect a leak in the exhaust system itself, so I'd imagine it's an EVAP leak. Where is this plastic tube you're speaking of? Back by the EVAP box? If so, I'd just go buy a hose-clamp or two and call it good. I doubt your installer is going to refund the cost of your dealer's diagnostics fees, but it's worth a try.
on
well about two weeks ago i had everything loosened and checked and then re-tightened. after another tank of gas we reset the light one more time. Its been two weeks now and it hasn't come back on. So now the problem is finnally fixed. I guess it was the octane boost that caused the problem unless we fixed it by rechecking the system.anyways im happy now and would not suggest anyone to use octane booster in their Z.
Justin100
11-29-2015 03:58 PM
