Z brakes are incredible!
Old Oct 7, 2002 | 07:47 AM
Zrated's Avatar
Zrated
Thumbs up Z brakes are incredible!
I don't know how the standard brakes are, but the Brembos are incredible. No matter how fast I'm going it feels like I just landed on an aircraft carrier, the car hauls to a stop instantly. This car is awesome!!!
Old Oct 7, 2002 | 08:18 AM
BILL T's Avatar
BILL T
Charter Member #61
I have to agree - this cars got fantastic brakes, even the standard ones on the touring are outstanding
Old Oct 7, 2002 | 09:01 AM
BrainStorm's Avatar
BrainStorm
I think overall, Nissan is really good on brakes. The Maxima, and my Spec-V brakes are also impressive. There's even a Brembo kit for the SE-R--the "Big Brake Kit" that comes with 13-inch rotors.
Old Oct 7, 2002 | 11:03 AM
gammbino350z's Avatar
gammbino350z
the stock brakes are wonderfull to. it barely takes any pressure at all to get this car to stop.
Old Oct 7, 2002 | 11:16 AM
DIGItonium's Avatar
DIGItonium
I'm still not used to the std. brakes on the Z. It's sensitive and stops as if I hit the wall!
John's Avatar
John
I've really been impressed with the brakes as well... I can't wait to see how well they perform at the track...
Old Oct 7, 2002 | 02:35 PM
m477's Avatar
m477
Default Re: Z brakes are incredible!
As for stopping distance, they are probably about the same. Tires are mostly responsible for braking distance, the Brembos is to reduce fade under repeated heavy braking.
Also, even with the Brembo brakes, if you are planning on doing heavy track racing, you will need to upgrade to racing-grade pads. Street pads aren't designed to handle the high temperatures that your brakes will create at the track. Track pads shouldn't be run on the street either, because they won't get hot enough and therefore will be too hard and will chew up your rotors.
You'll get a hint of how well the 350z was engineered to be a good track car when you try to swap out the brake pads and see how easy or hard it is....
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
