Go From 3rd To 5th Direct ??
Old Jul 3, 2004 | 07:40 PM
AZZGUY's Avatar
AZZGUY
Default Go Frpom 3rd To 5th Direct ??
I often shift directly from 3rd gear to 5 th - does anyone know if it does any harm?
Everything goes very smooth - so strange noises and shifts very easily. Your comments please.
Old Jul 3, 2004 | 07:54 PM
Nforce1's Avatar
Nforce1
If your at the right speed.... I wouldnt see any harm in it...
Old Jul 3, 2004 | 08:00 PM
samw1978's Avatar
samw1978
no harm, I do it often also
Old Jul 3, 2004 | 09:01 PM
MannishBoy's Avatar
MannishBoy
I tend to go from 4th to 6th all the time, skipping 5th. Modern transmissions can handle this with the synchros. Don't worry.
Old Jul 3, 2004 | 09:24 PM
Gerry's Avatar
Gerry
I do this also. No reason to use all the gears if your not getting on her
Old Jul 3, 2004 | 09:49 PM
AZZGUY's Avatar
AZZGUY
Originally posted by mc350z
yeah just driving around town i do it too and when i stop i dont downshift either i just take it out of gear and break.
I downshift sometimes - other times just slow down - depending on distance before stopping and speed traveling at the time. Feeling perhaps the clutch wear is less than the brake wear. I love to zip - but also not one to zip up to a red light 1/2 block away - let up on gas and let the engine do the braking - which I notice it does a better job in the stick than it did in the automatic. After slowing I will sometimes down shift once before braking
Thanks for the advice everyone - (hate to be paying for a transmission)
Old Jul 3, 2004 | 10:25 PM
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
I skip all kinds of gears without even thinking about it. I upshift and downshift and even shifted sideways once.
Old Jul 3, 2004 | 10:27 PM
shopdog's Avatar
shopdog
Default Re: Go Frpom 3rd To 5th Direct ??
When I want to ease around the neighborhood in a gas saving manner, I usually shift 1->3->5 or 2->4->6 depending on terrain. There's no need to go through every gear every time unless you're trying to do a power run. Fewer shifts mean less wear on the clutch and less wear on the gearbox.
Old Jul 4, 2004 | 06:34 AM
AZZGUY's Avatar
AZZGUY
Default Re: Re: Go Frpom 3rd To 5th Direct ??
Thanks! You have all put my mind to ease - didnt want to be doing something bad and find out in a year ( or less ) that I was ruining the transmission.
The Z is a fun - easy - car to drive!! Going to the mountains for the month of August - all thos mountains are real Z Country.
Old Jul 4, 2004 | 07:34 AM
CatastrophZZ's Avatar
CatastrophZZ
there shouldnt be any harm, unless you're going 120 in 5th and shift down to 3rd then yeah....
Old Jul 4, 2004 | 08:44 AM
ares's Avatar
ares
Veteran
I asked this many months ago. as I rarely ever hit 5th, sometimes no 4th either. I was told, its better if you shift into the gear, but never let the clutch out. just to let the synchros do their job for each gear rather than 1 synchro doing double duty. so thats what Ive been doing, I go 1-2-3-4-5-6 but I only let the clutch out when I want to accelerate in that particular gear.
Old Jul 4, 2004 | 09:36 AM
04evo2's Avatar
04evo2
If im going real fast at the end of third sometimnes i go from 3 to 6.
Old Jul 4, 2004 | 10:02 AM
cehome's Avatar
cehome
Man, I have to unlearn what I've been taught recently. I'm learning to drive stick before I take delivery of my Z. The instructor is always pounding into my head. "do not skip gears when upshifting". I do exactly what the original poster says. Go from 3rd to 5th directly. For some reason I have a hard time finding 4th gear.
Old Jul 4, 2004 | 10:11 AM
___DJK___'s Avatar
___DJK___
Thats what I do too.
Old Jul 4, 2004 | 01:37 PM
shopdog's Avatar
shopdog
That's crazy talk! :-)
The only time a synchro does any work is when there is a speed mismatch between the driving and driven gears. Since you should always speed match *before* shifting into a gear, the synchros should see minimal wear. However, if you are continually shifting in and out of gears *you aren't using*, you're just subjecting the synchros for those gear sets, as well as the shifting linkages, to unnecessary wear. Keeping the clutch depressed while doing those unnecessary gear changes also increases wear on the throwout bearing.
Old Jul 4, 2004 | 02:04 PM
MadMax76's Avatar
MadMax76
Can't do this, I got the obssesive compalsive crap going on, gotta go through all the gears .
Old Jul 4, 2004 | 04:14 PM
overlord tom's Avatar
overlord tom
Didn't the last few years of Camaro's and T/A's have that forced skip from 2nd to 5th or something under low throttle in order to meet EPA gas mileage regulations?
It does no harm at all. In fact, you DO get better mileage skipping gears. I usually do 1-2-6 myself in traffic, and keep it in 6th until speeds go below 25, then back to 2nd or 3rd. Even doing 0-40-0 mph two dozen times a day in gridlock, I still average over 21mpg. I'm impressed.
sales@czp
Sep 23, 2019 03:30 PM
Juztin
Nov 22, 2015 07:03 AM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
