RPM's too high
Old Aug 10, 2004 | 04:56 AM
illegal imports's Avatar
illegal imports
Default RPM's too high
It seem like my car rpm's are too high for only going 60 mph.
It's at about 3000 rpm's. It feels like it should shift to the next gear but
doesn't. If there's anybody out there that can check how high there rpm's
go at 60mph send me a response.
Thanks
Z-ya Later
Old Aug 10, 2004 | 05:30 AM
Jetpilot718's Avatar
Jetpilot718
Sounds like you're in 4th (assuming you have the AT model). Make sure you're not in sportshift while on the highway, you should be in D to get 5th gear.
Old Aug 10, 2004 | 06:22 AM
illegal imports
Default ITS AN AUTOMATIC 350Z
Sorry for not being specific its an automatic on D. I'm not using manual mode.
Thanks
Old Aug 10, 2004 | 06:45 AM
Jetpilot718
Well, my 6mt is at 2600 rpm in 6th at 70mph. So I dunno if that helps any... Talk to Nissan about it.
Old Aug 10, 2004 | 07:22 AM
ares's Avatar
ares
Veteran
is there an overdrive button anywhere? might be keeping you out of 5th gear or something... cause, yeah thats high if it really is 3000 at 60. might verify that your correct or your worrying about nothing.
Old Aug 10, 2004 | 07:23 AM
ares's Avatar
ares
Veteran
could also count the gear changes till 60. see how many gears you see.
Old Aug 10, 2004 | 07:24 AM
bigredc77's Avatar
bigredc77
Ever try taking it over 60? It should shift into fifth by the time you hit 65 or 70 (depending upon if you are flooring it or not). If that doesn't work then flip it into manual mode and shift up. And if you do shift into manual mode and the RPMs jump up even higher that is because you were already in fifth and it kicked down to fourth.
Old Aug 14, 2004 | 08:11 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Ive only driven a few Autos, but have always been at WOT
Old Aug 14, 2004 | 08:18 AM
ares's Avatar
ares
Veteran
I only have a manual, but Im at 2850rpm at 60mph in 5th. in 6th Im much lower. an auto's 5th is the same as the manuals 6th, so you should be much lower than 3000 in 5th.
check for over drive.
Old Aug 14, 2004 | 08:29 AM
350ZOWNZ's Avatar
350ZOWNZ
there is no over drive button. Go into manual mode and go to 60 again shifting yourself. You can go into 5th in manual mode. While in 5th if u are still at 3000RPM at 60MPH take it to the dealer... Im at around 2500 i believe
Old Aug 15, 2004 | 10:59 AM
AceJ587's Avatar
AceJ587
Mine sets down at 2200 RPM (no throttle) @ 60mph.
Old Aug 15, 2004 | 12:27 PM
Aggro_Al's Avatar
Aggro_Al
Mine is around 2300 -2500 if I'm in "D" and just cruising at 60. Switch over to manual mode and manually shift it into 5th. If you're RPM's are still high take it back to the dealer. If you are in 5th gear in auto mode don't forget that it is normal for the car to shift down to 4th when changing to manual mode. It is the equivalent to turning off the overdrive button on a regular automatic, from there you can upshift to 5th or downshift to 3rd. Also, if you are doing a lot of throttle or braking changes in auto mode or changing speeds a lot, the car may not shift into 5th because there may be no need to go to 5th. Make a conscious note to yourself to check what you are doing at the throttle. On the he 5AT in auto mode, you can override the computer temporarily for a short time from the throttle. On the upshifts, holding your throttle at the same postition or slightly accelerating will let the computer do its normal shift, accelerating rapidly will hold the shift or cause it to shift later and easing off the throttle slightly will do an upshift. Easing off a bit or braking will cause the computer to use the downshifting profiles. Your actions at the throttle and brake may keep it from going into 5th.
Listen for any sounds while you are shifting. Grinding sounds, long rattling noises or loud tapping isn't normal on the 5AT and is a sign of a bad transmission. A soft clunk sound or short clicking noises are normal when shifting out of "P" or "D" or when the transmission is shifting fast is normal.
If it is safe and you're in a safe location, try turning off the TCS and doing some quick acceleration in auto mode (no brake torquing). A normally functioning torque converter will put down a lot of torque right away. If your 5AT is revs high and feels like it pauses off the line you might have some slippage problems. If the torque converter is not locking up or it is free reving it will show up as higher RPMs.
Old Feb 27, 2022 | 09:35 AM
Micheal1975's Avatar
Micheal1975
ThanksZ-ya Later
Hey man have you tried your camshaft position sensor one of them take it to your local auto dealer or advance Auto and have them run the machine on it and see if it throws any codes I almost guarantee it'll throw a code for that that effects quite a bit of the I just went through it my car was starting out like in third gear and once I got up to speed it was fun but it would never switch into fifth gear so I replaced it and so far it's doing better
Old Feb 27, 2022 | 10:06 AM
travlee's Avatar
travlee
Master
17.5 year dead thread
Old Mar 31, 2022 | 09:02 PM
carlos302's Avatar
carlos302
My rpm gauge is stuck in 2800... engine works fine....any sensor???
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Justin100
Nov 29, 2015 03:58 PM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
