Im having these 3 lights ON (engine,VDC,slip) since last one month,
Old Jan 16, 2022 | 10:23 PM
Sagar bhandari's Avatar
Sagar bhandari
The engine light comes first, thn within following two seconds the vdc and slip lights comes,
Old Jan 17, 2022 | 05:01 AM
Heel Til I Die's Avatar
Heel Til I Die
If you don't want to take it in to the dealer and you are trying to fix it yourself, type this in to google and you'll get about 400 results...
cel vdc slip site:my350z.com
Old Jan 17, 2022 | 09:18 AM
Spike100's Avatar
Spike100
It sounds as though your car is going into Limp Mode. The computer is signaling the engine that the car should not be driven. As Heel Til I Die points out, there can be many faults that cause this. Two common faults are a dirty throttle body, or a faulty or dirty MAF sensor.
Old Jan 17, 2022 | 02:22 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
"Scanned but throwing no code"
Not one you can see anyways.
What kind of reader are you using? Not all of them will dig into all of the subsystems. You are definitely going into limp mode and there are myriad causes from a P2135 (or something like that, throttle position sensor) to a hardware issue unrelated to the engine itself, e.g., faulty speed sensor(s), brake sensors, etc.
Probably need a full scan with Nissan Consult III. This reads engine, brake, BCM subsytems, etc. Dealer or Nissan specific shops will all have them (plus select individuals).
Old Jan 17, 2022 | 05:10 PM
travlee's Avatar
travlee
Master
Can someone merge his 5 threads together?
Old Jan 18, 2022 | 02:51 PM
MicVelo's Avatar
OK, this is the last time this thread will be seen. You ask the same question 5 times and respond zero times to people that give you some thought on it. No more. The other threads are deleted and you will be too if you keep asking the same and not responding. Simple.
Old Jan 19, 2022 | 06:13 AM
motohp's Avatar
motohp
Crank position sensor.
Old Jan 19, 2022 | 01:18 PM
Spike100's Avatar
Spike100
I would like to repeat Mic's message because it provides some very telling information. Not all readers are the same, The Nissan Consult III provides a more extensive analysis for Nissan cars than many of the generic readers (even the more expensive devices).
Old Jan 21, 2022 | 02:20 PM
CFAUVEL's Avatar
CFAUVEL
I have exactly those lights that came on on my G35 when it stalled going about 15 mph....My code is for Cam Shaft position sensor. I think there IS something to be said that the computer is trying to tell you to STOP, something seriously aint right.
Old Apr 1, 2022 | 07:09 PM
CFAUVEL's Avatar
CFAUVEL
So I replaced the Passenger Side cam shaft position sensor and cleared the codes. The car started and ran fine, but the VDC and SLIP came back on. I read somewhere here that sometimes the master Cylinder float level could be the culprit. I added more brake fluid to go pass the MAX line level and sure enough the light has not come back on since I did that.
Old Apr 1, 2022 | 07:26 PM
MicVelo's Avatar
Thank you for the follow up with a solution. Good catch. Gotta love the simple fixes.
travlee
Jan 17, 2022 02:09 AM
Jetikgnt
May 7, 2013 07:03 PM
Negligence
Sep 19, 2011 08:23 AM
350z on DUBZ
Mar 17, 2006 10:18 AM
Strand
Jan 21, 2004 05:44 PM
