Bored with the rain, so I installed my strut brace and emblems..
on
I was a little bore her in Los Angeles Cali because of the rain, so I stalled my New JIC strut brace and Z emblems.
Here is the new JIC strut brace. Much more rigid and is about the same weight. Very easy to install. Just make sure your on a level surface.
Here is a straight on shot of the strut brace
This is a close up of the mounting bracket
Here is a shot of the new rear emblem. Sorry about the light, but it's been raining...
Here is a shot of the front emblem
I will have performance nissan install my Stillen sways in a day or two.
Later
Later
Twisty addict
on
Re: Bored with the rain, so I installed my strut brace and emblems..
Originally posted by samurai1
Z emblems.
Z emblems.
on
Re: Re: Bored with the rain, so I installed my strut brace and emblems..
Originally posted by zwindsor
Mine will arrive soon. How did you get the old ones off? I was planning on heating them up with a hair dryer and prying them off. Do the new emblems have pins on the back too?
Do not try to pick it off or you will have a big adhesive mess you will need to clean off with alcohol. The front emblem is a little more difficult because of the recess, but not bad. The front emblem has several guide pins built into the bumper, but you still need to center it right. The rear emblem is a little bit harder. You can use masking tape as a guide to where the old emblem was centered. On my 04 Z trunklid there were two holes where the old emblem guide pins go. The new emblem does not have any guide pins. Make sure to cover those holes with the new emblem. Use the masking tape as a guide to set the new emblem. The new JIC strut brace was easy to install, but you do need to remove a few strap connectors for wires that are connected to the original strut brace mounting brackets. One of the connectors you do not need to worry about. The large one going to the battery I used a wire harness divider like the ones that separate you spark plug wires to hold it in place. I will be taking my Z into the mountains today since it has stopped raining!!! I finally can drive some high speeds again I just have to watch out for rocks on the mountain roads...
Later
Later
Originally posted by 350ZR2004
What do the struts do for you on the highway ramps?
umm...the struts are supposed to make the car handle and turn better. Am i correct? With that said-pulling onto an offramp at high speeds would keep the passenger inside feeling a little safer. Less body roll. U can take turns at higher speeds..
04-04-2016 07:52 AM
