2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Ethanol 350z is for real. Wow.
Old Apr 29, 2008 | 02:45 PM
cdizzle's Avatar
cdizzle
Question Ethanol 350z is for real. Wow.
So I happened to pick up a copy of Modified recently, cause obvioulsy I was curious about Enjuku Racing's 350z drift car. Then when I read the article, it says that their Z runs on E85, but unfortunately no details on how they did it. Booo! Well, if any more E85 stations pop up in CA (which will not happen for a while), I don't mind coverting my Z.
I'm just wondering how Enjuku did theirs so far? Any good technical theories out there? Or does someone actually know how they did it? Please respond and spit your E85 Z knowledge.
Thanks!
Old Apr 29, 2008 | 02:48 PM
cdizzle's Avatar
cdizzle
Oh Crap. Posted this on the wrong thread. Can a mod stick this in the appropriate place for me and everyone else. Thanks!
Old Apr 29, 2008 | 04:55 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Old May 6, 2008 | 11:59 AM
BrianV's Avatar
BrianV
You can run higher compression on E85, but only if it's E85 only.
Old May 6, 2008 | 05:56 PM
07_350z_JP's Avatar
07_350z_JP
BOOO-- Ethanol is the biggest hoax ever at least for the USA. We americans are simply not disciplined.Took Brazil 30+ years to be considered a success. Brazil is successful but look at what 98% of the people drive/ride there.Most Americans have no regard for anything other than instant gratification.
Old May 6, 2008 | 06:35 PM
RxZ's Avatar
RxZ
Ethanol can eat up the rubber that is in the fuel system , so obviously that needs to be replaced. Also, E85 has an octane rating of something like 105, so the ECU needs to be remapped for the changes. Also, E85 has ~65% the energy that gasoline has, so again, the ECU needs to be modified to control the correct amount of fuel to get to the engine.
All in all it is not that much that has to be done. However, it is not cost effective to run E85 due to the lack of fuel mileage, and the fact that E85 costs as much as normal gas across much of the country. That and it causes the US not to ship as much corn overseas so we can use it ourselves.
If a car is designed from the ground up to use E85 though, it can get better gas mileage than a gasoline equivalent. The Z is not that car though.
Old May 6, 2008 | 07:29 PM
Jspeed's Avatar
Jspeed
Good info.
The solution for optimizing an ethanol/petrol flex-fuel engine is to run a turbo. Raising the boost when there's higher percentage of ethanol in the tank would take advantage of its higher octane.
Old May 7, 2008 | 11:30 AM
BrianV's Avatar
BrianV
Yeah checkout the Konigsegg (spelling?) CCXR with the E85 conversion, it makes like an extra 200HP.
Old May 7, 2008 | 12:05 PM
RxZ's Avatar
RxZ
Originally Posted by Jspeed
Good info.
Correct. There is a car in Europe that gets better mileage using E85, and has more horsepower and other performace numbers, because its drivetrain was designed to use it. It has a smaller engine than its gas counterpart, and uses a small turbo to make full use of 100 octane fuel. If a car is designed with this in mind it will work. However, most American vehicles that run on E85 also run on gas, and due to the engines limitations, they get worse gas milage and a little bit worse HP/TQ when using E85. At least this has been my experience to date.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
