2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
UK EVO Magazine on Z370
Old Feb 4, 2009 | 11:40 AM
WestRace's Avatar
WestRace
Default UK EVO Magazine on Z370
http://www.evo.co.uk/carreviews/evoc...ssan_370z.html
Sharper and more powerful, Nissan’s new 370Z gains the edge
January 2009
"The biggest changes are in the chassis. From the first corner it feels more accurate and precise"
Koblenz. The sign clearly says Koblenz. My geography isn’t great (despite being quite handy at colouring in), but the last time I looked, Koblenz was in Germany. And yet I’m pretty sure I woke up at 2am this morning with terrible jet lag on North Island, Japan. Odd. We’re driving on the right, yet the box-shaped vehicle we’re in is right-hand drive. Those trees look awfully German too. My head’s starting to hurt.
Wherever I am, I’m one of four UK journalists who are about to drive the new Nissan 370Z. It’s late October and the car is still very much under wraps, but our quartet has just had the full press presentation and I’m now very excited about the new Zed. Shorter, wider, stiffer and with more power, it should be an absolute cracker. Nothing less than beating the Porsche Cayman will do for Nissan…
The 370Z, as its name suggests, now has a 3.7-litre V6, which produces 326bhp at 7000rpm and 269lb ft at 5200rpm (the 350Z had 309bhp and 264lb ft). The overall length of the car is 65mm shorter, while the wheelbase has been reduced by 100mm; the engine is also mounted slightly lower than before and the driver sits some 15mm closer to the ground. The engineer giving the PowerPoint chit-chat also seemed very proud of the fact that they have reduced the weight of the new 370Z by 110kg. Except they haven’t. In the process of improving the car, meeting safety regulations, etc, the engineers ended up increasing weight by 110kg, but they then managed to strip the same weight back out again by making the doors, bonnet and boot out of aluminium. So after all that, the 370Z weighs exactly the same as the 350Z – just over 1500kg.
The wheels and brakes come in two different packages. The basic set-up is 18in cast alloys with floating calipers on the brakes, but the S and ST models – which we’ll be driving today – get 19in forged alloys hiding 355mm discs at the front clamped by four-piston fixed calipers. The suspension retains a multi-link set-up at the rear, but the front has now been switched to double wishbones.
The six-speed manual gearbox remains the default choice for the Zed, although it now comes with something called Synchro Rev Control, of which more later. We never got the automatic 350Z in the UK (and I don’t think we were missing out on much), but the 370Z will be coming to us with the option of a new seven-speed auto complete with paddle-shift.
Once the press conference had ended we were ushered into the two right-hand-drive boxes on wheels, which turned out to be Nissan Serenas. We are – in case you hadn’t guessed – at Nissan’s Hokkaido Rikubetsu proving ground. It was built around 20 years ago and is the only one of Nissan’s four (four!) proving grounds to feature a ‘country course’, a high-speed circuit with no banked sections (completed only a couple of years ago) and a cold-climate test track. Although there’s no snow around at the moment, it is noticeably colder up on Japan’s North Island compared with Tokyo, where we flew in a couple of days ago. It’s a sort of dry chill that speaks of high altitude.
As we trundle over a bridge onto the infield of the high-speed track, everything changes from Japanese to German. We really could be in the Eiffel Mountains and approaching the Nürburgring. Apparently even the conifers were specially imported to match those found in western Germany. Quite what improvement this arboreal transplant has had on the development of the 370Z I don’t know, but the effect is striking. Surrounded by the deciduous sea of autumnal colours that makes up the Japanese countryside, the proving ground must look like a dark green pool of evergreen Germanity if you’re flying over it.
As we turn off the wide access road onto a smaller tributary, a yellow sign points towards Tiergarten. We approach a small sort of congregational area, complete with marquee and a trio of 350Zs that we drive first to aid comparison with the new and hopefully improved model. The 350 is in many ways the antithesis of its bigger brother the GT-R. It is quite an old-fashioned car, complete with a resolutely hefty manual gearchange, rear-wheel drive, not a sniff of charged air near the engine, and electronics that don’t stretch much further than an ESP button. It is, however, a wonderful formula that allows a driver myriad options in a corner, and it’s been one of our favourite cars for the last five years.
We’ll get just three stabs at a ten-minute test route around the proving ground in the 370. Each time around we’ll take in the twisting country road, followed by a lap of the high-speed autobahn loop. The country road is a two-lane affair, starting open and flowing, before getting tighter with some good second- and third-gear corners. The tarmac then dives into a more enclosed section with Armco worryingly close. Here there are some technical corners with bumps viciously inserted into apices, and tightening radiuses added to make both you and the car feel a bit unsettled. It dips and crests in a very Nordschleife sort of way too.
The high-speed section is not quite as exciting as it sounds because these cars all have the Japanese Domestic Market limiters on them. As a result, you feel an invisible forcefield grip the car at about 112mph, after which you can simply sit back and enjoy the view and the various and varied surfaces that have been set into the inside lane.
It gets dark early here so I’m rushed politely and with urgently inviting bows into the 370Z for the first time. It has a semi-keyless system so you simply need to have the fob about your person and then press the starter button, after which the car starts with a slightly deeper, more guttural sound than the 350. The clutch still requires a little finesse off the line and the gearbox still has that chunky weight to the stubby lever. Up the hill for the first time and a slightly surprising absence of low-down torque remains, although the V6 spins more easily through the lower register and up to the top end where it does its best work. It’ll be interesting to see if it can match the very bold 4.4sec to 60mph claim…
The biggest changes are clearly in the chassis, though. From the very first corner the steering is noticeably more accurate and precise. Torsional stiffness has been significantly improved and it feels like it, with the nose turning more immediately and the shorter wheelbase carving a line through the corner more acutely. In the 350 there was a slight delay between the moment you turned the wheel and when the tyres reacted; in the 370 there is much more immediacy. In fact the whole car feels laterally stiffer – where previously loading-up the 350Z’s chassis in a corner felt like leaning against a softly padded wall, it feels like you come up against resistance from the 370’s Bridgestones much more quickly.
The downside to all this improved responsiveness and added rigidity is a ride that has become noticeably firmer. It’s still well damped, but there is more road-noise and chatter coming up into the cabin. It doesn’t upset how the 370Z performs and I’m pretty sure it won’t be fazed on a Welsh B-road, but I do wonder if the added harshness might put off a few less committed customers who are looking to use the car on a day-to-day basis.
As I get back to our temporary car park for the first time, however, I’m in no doubt that the 370Z is more focused as a drivers’ car, and that is good news. You can make up your own mind about how it looks, but walking around the selection of cars whilst others are out driving, I come to the conclusion that the brighter colours look best, and happen to think that it looks better in motion than at rest. I also love the ‘Z’ indicator repeaters on the front wings and the way the outline of the side windows resembles that seen on the GT-R.
Lift up the rear hatch and you’ll notice that the large strut that used to brace across the rear axle line of the 350Z has moved to directly behind the seat-backs, thereby freeing-up a veritable cavern of luggage space. The seats themselves are identical to those in the old car, but now have sueded sections to them, which help to stop you sliding around when you’re sliding around (if you see what I mean). The steering wheel still has a nicely slim rim, but the spokes have now been slimmed to match, and it feels more in keeping with a sports car. The dials behind it are bigger than before, with the focus very much on the large rev-counter in the centre, which now also houses a gear indicator. And the whole instrument binnacle still moves with the wheel, just like it does in the 350Z.
Old Feb 4, 2009 | 02:46 PM
xxgreatwarsxx's Avatar
xxgreatwarsxx
good article, thanks for posting
350Zin'L.A.'s Avatar
350Zin'L.A.
im pretty sure no1 is reading this... and i dont know y im commenting it. but i hope they said good things about the 370
edit.. forget what i said.. sorry
Old Mar 4, 2009 | 08:32 PM
jmwlenz's Avatar
jmwlenz
when did Nissan claim 4.4sec 0-60 for the 370Z???
Old Mar 9, 2009 | 07:52 AM
trebien's Avatar
trebien
Back in October, when these journalists were testing the car. Also, back when everybody was predicting all the 12 second time slips.
Old May 25, 2009 | 02:33 PM
htt760's Avatar
htt760
that was a good article thanks
Old May 27, 2009 | 03:02 PM
CaliTouring's Avatar
CaliTouring
someone make an audio version.
Old May 27, 2009 | 03:09 PM
3FIDDYZED's Avatar
3FIDDYZED
Was reading this in the station on my way home today. The car is receiving some great press over here... Think the last V's test I saw was 370 v Coxter S, Gayman, new z4 and SLK... Was deamed a close no3 to the coxter with the gayman winning... But was deamed best bang for buck.....
New Top Gear mag had a great article about gt-r Spec-v V 911 GT-3 on the ring....
Old May 28, 2009 | 04:26 AM
dennisafrompa's Avatar
dennisafrompa
Coxster??, Gayman??....credibility goes down when you need to use those terms.
I like the 370, and it appears to be a great value and a great performer, but why do you feel the need to slam the Boxster and Cayman.
I was one who experienced engine failure (IMS bearing) in my Boxsters (an '02 and '04), and now own a 350Z yet don't feel the need to use those terms.
Old May 28, 2009 | 09:17 AM
WestRace's Avatar
WestRace
It's just British humor.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
leonchus
Sep 29, 2015 07:04 AM
dcains
Sep 21, 2015 09:28 AM
