2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
350z HR VS 370z Video
Old Jul 28, 2009 | 10:42 AM
  #121
One_Quick_Z's Avatar
One_Quick_Z
370Z TOURING NISMO 370Z
Manual transmission 3,232 3,278 3,300
Automatic transmission 3,269 3,314 N/A
These are the actual weights of the cars
Now there are several other factors that can contribute to the change of the weight
The car holds 19 gallons of gas at ruffly 6lbs a gallon that is 114lbs if you have only a 1/4 tanks when you weigh your car that is taking 70lbs out of the car
Also the weight of the driver can come into play also if you are tracking your car and need to make it more balanced
DAN
Old Jul 28, 2009 | 11:00 AM
  #122
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Again it was proven on the 370z forum that Nissan's numbers were not correct as people have weighed their cars.
DAN
Old Jul 28, 2009 | 11:24 AM
  #123
lugrug's Avatar
lugrug
From the this thread:
https://my350z.com/forum/2009-370z/4...car-build.html
"We are sitting right now at just over 3300lbs with a full tank of fuel"
Actual weight on scale was 3323
Given a full tank of fuel weighs 114 lbs.
3323
-114
3209 dry curb weight
..or lighter than the actually claimed 3232 (and that is w/o the sports package this car actually had). I'm assuming that the tank wasn't quite full.
Old Jul 28, 2009 | 11:26 AM
  #124
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
So it weighs the same as my NISMO did at 3/4 of a tank of fuel. And my NISMO is heavy.
Old Jul 28, 2009 | 11:28 AM
  #125
Nexx's Avatar
Nexx
so 3300 pounds makes your nimso heavy but a base around 3250 or so is light?
Old Jul 28, 2009 | 11:32 AM
  #126
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I seriously doubt a base will drop that much weight over a Sport. C&D weighed a base w/sport and it was 3350. So explain that and the others that weighed their cars around 3350?
The car is not lighter, it is on par with the 350z later years. The early 350z years were lighter.
Old Jul 28, 2009 | 11:36 AM
  #127
theDreamer's Avatar
theDreamer
Many reviewer cars were given an oil cooler and such which will add weight, which was removed for final production.
Old Jul 28, 2009 | 11:40 AM
  #128
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
A oil cooler does not add that much weight.
Old Jul 28, 2009 | 11:44 AM
  #129
scotts300's Avatar
scotts300
Which is a huge FAIL. And for the Z34 NISMO to not come with one is reason enough to look at a different car. I was hot-n-heavy for a Z34 NISMO, but no OC and the standard VLSD for $40k - seriously? So you get nice seats, a marginally better suspension, and 150# of downforce for $8k over a new Z34? No thank you.
  #130
theDreamer's Avatar
theDreamer
10 pounds (maybe more) is still 10 pounds.
Old Jul 28, 2009 | 11:46 AM
  #131
theDreamer's Avatar
theDreamer
Which I agree with, them to forget that cooler really turned a lot of people off. But by doing it they can now void your warranty for tracking your car and just say, "Well no oil cooler, so we did not intend it for track use," which is complete BS considering all the extra items added which contribute to a track car.
  #132
lugrug's Avatar
lugrug
The guy on the "other" board got a weight of 3323 with a claimed 3/4 tank of gas. After subtracting gas weight , that leaves 3238 and he has the sport package. I've read the sports package adds between 40 and 50 lbs but haven't seen anyone figure out how to actually weigh it. Seems Nissan's weight claims are a bit high if anything.
Old Jul 28, 2009 | 11:50 AM
  #133
theDreamer's Avatar
theDreamer
Weight factors of the sports package would be:
~Bigger wheels/tires (though the Rays are only 24 and 26 pounds)
~Rear spoiler
Everything else will be minor, but might add up to 10-15 pounds total for the other electronics and brakes.
Old Jul 28, 2009 | 11:52 AM
  #134
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Cars are usually weighed with a full tank of gas. So if you empty my tank then my car would be in the 3100-3200 lb range right?
Old Jul 28, 2009 | 11:53 AM
  #135
lugrug's Avatar
lugrug
~Rear spoiler
An actual Nissan doc claimed somewhere around 46 lbs I believe. I have no reason to doubt them. I doubt they would oversell the weight.
Old Jul 28, 2009 | 11:55 AM
  #136
Spork's Avatar
Spork
The 03-05 350z were even lighter than that.
Yeah, but the 03-05's only had like 200hp.
The 07-08 HR has like 600hp and can rip 12" diameter trees out of the ground, all while saving the ozone layer and curing cancer. The Nismo trim adds the ability to solve world hunger and being able to carve corners like an F1 car.
I mean sure the 370Z is lighter, wider, and more powerful... but it can't defy physics like the 350Z HR can.
Old Jul 28, 2009 | 11:59 AM
  #137
lugrug's Avatar
lugrug
I've always heard official weights are with empty tank but don't have any reference to it. Either way, I'd assume Nissan has done it the same way with both the 350Z and the 370Z.
Old Jul 28, 2009 | 12:02 PM
  #138
lugrug's Avatar
lugrug
03-05 Z's have great weight but weak engine
06-08 Z's have better engines but lot's of weight
09 Z' weight falls in between in weight, has better power, but you have to live with "fangs".
Old Jul 28, 2009 | 12:24 PM
  #139
scotts300's Avatar
scotts300
I drove a 370 with Sport package and nearly-full tank of gas on the same scales that I use. I was surprised when it read 3380#. It was completely stock at the time.
Old Jul 28, 2009 | 12:25 PM
  #140
One_Quick_Z
Wow you are making a big deal out of nothing at all nissan only said they made it lighter and they did.....they did not however specify how much weight they actually removed
It is lighter and that is that..... they removed somewere around 150lbs of weight which is right because the 370Z 3250 give or take compaired to 3400 of a touring 350z
370Z is a better car end of thread.
DAN
