premature brake wear
Old Sep 25, 2005 | 09:43 AM
danmar's Avatar
danmar
Default premature brake wear
my 04 roadster has 9,000 miles and when I took it in for its oil change advised service of a squeaking problem now they tell me the brakes are gone and have some rotor damage. I drive it short distance to work 6 miles to and from, rare freeway driving no stop & go traffic. anyone else having this problem?
Old Sep 26, 2005 | 01:55 PM
NAPZ's Avatar
NAPZ
I had the problem at 13'000 miles. Not real sure of why, they just told me they wore down and it was covered under warranty. I asked if this happened often or should I expect it to happen at 26'000 miles they said " That it doesn't happen often blah blah" and tried to elude to me driving it to hard as the problem.
Old Aug 16, 2006 | 03:50 PM
thepostman's Avatar
thepostman
if you don't have the service manual, i suggest to spend the $300 and buy it. it will have all measurments needed especially in the case of rotor wear. I just replaced my pads at 32,000 and the rotors were worn really thin. the wear limit is 22 mm and this is important to have in your back pocket so u dont get shafted. i was able to get one cut of a resurface done and will need to buy new rotors at ~60k. Continuing to buy new rotors every 9,000 miles sounds absolutely ridiculous regardless of driving style....
Old Aug 18, 2006 | 07:40 PM
DeZigner's Avatar
DeZigner
I have a 2004 Roadster with 30,000 miles. I just had my mechanic check out my brakes. He said they were about half gone and I would probably need some new pads around 55,000 miles.
FWIW
DeZigner
Old Aug 18, 2006 | 07:45 PM
zand02max's Avatar
zand02max
In my opinion, its all how you drive!
Old Aug 18, 2006 | 07:48 PM
Built2shredZ's Avatar
Built2shredZ
I think brake wear really depends on the driver...
Me and my brother inlaw both had 2000 preludes his was an automatic mine was a 5MT, It took me about 38k miles before I went thru my first set of brakes, he had to replace his at 16k... When I rode with him he was a very aggresive driver, always tail gating and hitting his brakes... When I tried to point this out to him he was like in total denial.. He swears he drives the same way I do LOL
Old Aug 18, 2006 | 07:51 PM
zand02max's Avatar
zand02max
+1!
Old Aug 18, 2006 | 11:59 PM
iceman21_23's Avatar
iceman21_23
im at 10.700 and im getting lots of squeaks, but then again i drive it like i stole it so meh...
Old Aug 21, 2006 | 09:08 AM
driftk1d's Avatar
driftk1d
my brakes squeal when i touch them lightly...is this normal? i have about 11,000 miles on my car.
Old Aug 21, 2006 | 11:52 AM
Built2shredZ
Either there dirty or you might need to replace them
Old Aug 21, 2006 | 10:48 PM
OUphidelt's Avatar
OUphidelt
I had all four rotors replaced under warrenty at 7000 miles, and now they are squeeling at 22 k miles...so they will be replaced again.
Old Aug 21, 2006 | 11:03 PM
plumpzz's Avatar
plumpzz
Mine does it too, and i've been told by my neighbor who is a mechanic that they're dirty. How do you exactly clean brake calipers/pads?
Old Aug 21, 2006 | 11:07 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
How long was the warranty for brakes?
Mine squeak all the time now. I think you can use anti squeak gel or paste from Pepboys.
Old Aug 22, 2006 | 04:08 AM
stonecrd's Avatar
stonecrd
I have 20,500mi on mine and just had service. The breaks are original and they did not push me to get them replaced.
Old Aug 22, 2006 | 04:15 AM
savvy's Avatar
savvy
i'm at 9.5K with absolutely no brake problems whatsoever....my front rims get dirty black after only a week though from all the brake dust
Old Aug 22, 2006 | 04:43 PM
Zster'n's Avatar
Zster'n
Default brembo's
are we talking about brembo's or others. I have a ZR with 20000kms and brembo's. I think they are wearing thin
Old Aug 24, 2006 | 07:34 AM
REDROADSTER350Z's Avatar
REDROADSTER350Z
hopefully mine does not wear out or need replacing till about 30k,
does anyone know how much stage 2 stop tech bbk's are?
Old Aug 26, 2006 | 12:27 PM
geterdone's Avatar
geterdone
hey zster'n were in canada are you from
samansharif
Sep 25, 2015 12:31 PM
