convertible top problem
Old Aug 17, 2012 | 05:50 AM
  #121
Dirk Logan's Avatar
Dirk Logan
Default 2004- 350Z had new top installed now top won't close all the way
Purchased an aftermaket top by Robbins for my 2004 350z and to close & lock the top I have to push the top down in the front. Also when opening the top the back hatch has to be pushed down in order to close completely and turn off the yellow (top) indicator. Can anyone advise what needs to be done to fix this problem?
Old Aug 23, 2012 | 03:26 AM
  #122
SHILOW's Avatar
SHILOW
The top will stretch, just give it a little time. If you park in a garage, leave it folded over night.
Old Sep 4, 2012 | 10:44 AM
  #123
out&about's Avatar
out&about
Smile My 05 350Z top will stop
Has anyone had any trouble with the top opening and then stopping just before it goes into the compartment? We changed the 5th bow motor and it still does the same thing. It goes up from that position with no problem. We have even lubricated it since we were told that is what it needed. Any suggestions?
Old Sep 10, 2012 | 08:04 AM
  #124
SHILOW's Avatar
SHILOW
Try pushing down on the second bow as the top folds. The elastic straps wear quickly and the second bow can cause your problem if it itsn't positioned correctly as the top folds.
Old Sep 10, 2012 | 01:33 PM
  #125
out&about's Avatar
out&about
thanks for your info. I had the straps replaced and that did the job..
Old Jan 22, 2013 | 07:43 AM
  #126
sparticus's Avatar
sparticus
Does anyone know where I could take my 2005 350z with a 5th bow issue to get fixed in Columbus, GA? Atlanta, GA?
Old Jan 30, 2013 | 03:45 AM
  #127
SHILOW's Avatar
SHILOW
If the 5th bow motor is the problem you can replace the brushes in the motor for less than ten dollars. There is a 'how to' on this forum with pics. You should try it before you take it to someone who will charge you $1000 to replace it with a new one.
Old Feb 3, 2013 | 06:59 PM
  #128
sparticus's Avatar
sparticus
I've seen the how to forum, but I'm too scared to try it.
Old Feb 4, 2013 | 03:27 AM
  #129
SHILOW's Avatar
SHILOW
If you're getting the motor replaced anyway it doesn't matter if you can not complete the job. A $10 fix as oppossed to an $800 one is worth a try.
Old Feb 8, 2013 | 06:59 AM
  #130
shakyj's Avatar
shakyj
Default Convertible top won't go down SOLUTION
I had the same problem and the dealership had to replace the top. Call the corporation get a claim number, if your car isn't under warranty. They are tracking this problem and will probably replace it.
If you go to:
http://x.nissanhelp.com/forums/
You will see all the "service bulletins" on any Nissan car. I couldn't believe that the 2006-350z DIDN'T have any recalls! When it's over 300 owners here with the same problem. But the 370z have recalls?
I think if people start calling the Corporation to get a case number. This will open their eyes to our problem. Maybe, we can start getting some recalls.
So, please owners just call and get a case number started; then you can go off and fix it yourself.
Old Feb 8, 2013 | 07:04 AM
  #131
shakyj's Avatar
shakyj
Default Issues
If you go to:
Old Mar 3, 2013 | 09:42 AM
  #132
shakyj's Avatar
shakyj
The top is covered under warranty. However if your warranty has expired go the dealership to get it documentation and then call the corporation to file a complaint.
My entire top had to get replaced but it was still under warranty, so Nissan knows about this problem.
Hope this helps out.
Old Mar 3, 2013 | 09:52 AM
  #133
shakyj's Avatar
shakyj
Exclamation Convertible top Solution
Old Mar 3, 2013 | 10:00 AM
  #134
shakyj's Avatar
shakyj
Originally Posted by joepark
I was another recent post. I am having a similar problem. I tried to open the top, then windows went down but top stayed up. When I press the button it sounds like it trys to open but stops. Also, the light for the top came on. any ideas what is wrong?
Issues
If you go to:
Old Dec 4, 2013 | 01:32 PM
  #135
jgc0726's Avatar
jgc0726
Hey guys I have an 06 enthusiast convertible and the top won't go down at all it won't even make noises to let me know that is even trying to move. Has anybody experienced this problem?
Old Dec 13, 2013 | 12:25 PM
  #136
SHILOW's Avatar
SHILOW
We need a better description of your issue.
Step one: You have to apply pressure to the brake pedal for the top to start to move.
Old Dec 13, 2013 | 01:06 PM
  #137
jgc0726's Avatar
jgc0726
Yessir i do everything hay your suppose to do for the top to start moving but nothing happens, no movement no noise nothing
Old Feb 20, 2014 | 04:41 PM
  #138
nerdhiker's Avatar
nerdhiker
How would one get the straps replaces? Is it a DIY job or do I need to get it done by a professional? If I were to buy parts, are they expensive (the straps I mean)? Whats the part #?
Old Feb 20, 2014 | 05:51 PM
  #139
Blooster's Avatar
Blooster
There's an excellent tutorial here: https://my350z.com/forum/350z-roadst...-tutorial.html
Bought 2 straps from the dealer at $11 each and it took about an hour to install them. For my '05 the part number for the straps was "97150-ce01b - Cover Assy-Fold".
Old Apr 8, 2014 | 12:45 PM
  #140
myfairlady33's Avatar
myfairlady33
Originally Posted by DocJ
I had similar problem on my 05 zr. Started with 5th bow sounding sluggish & weak like motor was straining. Had several times where it wouldn't budge, but heard the latch in back "click" with top indicator light coming on. Sometimes with several attempts it would go. Finally got to where it wouldn't open, but windows & such would go down like normal early cycle. Turned out it wasn't my 5th bow motor, but some sort of regulator that controls all the different motors cycling at specific times. Luckily, I had purchased an extended warranty which covered most of the repair cost. Just fyi, may not be the 5th bow motor which is what I had expected to hear.
I am similar problems with my 2004 Z roadster.I did some checking out off components from the service manual.So far I found the control uniti might be bad. I checked from terminal 27 to ground and should be 5 volts and had 0.I'mstill going to run through the checks for the 5th bow motor.Was it the control unit that got replaced on your car?
