Knocking sound after driven for 10 min.
Old May 14, 2015 | 11:22 PM
Serithin's Avatar
Serithin
Default Knocking sound after driven for 10 min.
Never knocks on a cold start. After I drive 10 or so min it will knock at idle and go away an 2krpms and up. Let off gas and as soon as idle hits sub 1k knock comes back. Mechanic thinks it could be duel mass flywheel (which is going to be changed with the clutch on Monday) But I cant wait that long for a diagnosis. Nissan will diagnose it for 100$ but its kinda far from my house and the flywheel replacement might be the problem. My question is this.. Is this a common problem with the clutch flywheel to make a knocking noise or is it likely to be something els? The car has 66k miles and (the motor) drives like a dream at high rpm's.
Old May 15, 2015 | 06:22 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Impossible to even guess from your loose description of "knocking". It is NOT a common problem for a clutch/flywheel to knock, but even if it's not, a rod or main bearing failure causing a knock would be even worse news. If you can't wait until over the weekend to get a more definitive answer, you could get one when your revup blows up in your face. Better to be conservative with your driving and be sure to check your engine oil level.
Obadabot
Jun 18, 2023 11:31 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
