2004 Roadster trunk struts question
Old May 21, 2015 | 04:49 AM
Makriluc's Avatar
Makriluc
Question 2004 Roadster trunk struts question
Are the trunk struts of a 2004 Roadster with OEM spoiler the same as without spoiler?
Thanks
Old May 21, 2015 | 05:33 AM
Heel Til I Die's Avatar
Heel Til I Die
I may be wrong, but I was under the impression that the roadster did not come with a spoiler from the factory. If you do have a spoiler, then most likely, it has been added on. The struts should be the same unless someone put in different ones as well.
Are you asking because your trunk won't stay open?
Old May 21, 2015 | 08:07 AM
Makriluc's Avatar
Makriluc
Exactly.
The trunk won't stay open unless it is fully open.
Ok, I didn't know the Roadster did not come with a spoiler from factory.
Not my car but this is the spoiler I have
So would you say I need stronger struts or would the standard ones do?
Thanks
Old May 21, 2015 | 08:42 AM
myork's Avatar
myork
I dont think there is anything wrong with your struts - they are not multi-position.
Trunk is either fully open or closed, the struts are just to keep the trunk lid from crashing onto your lid while you are rummaging through the trunk.
Old May 21, 2015 | 09:54 AM
jhc's Avatar
jhc
General & Tech Moderator
You are correct.
Old May 21, 2015 | 10:21 AM
Heel Til I Die
Agreed. I think your struts are fine as long as your trunk stays open when you fully open it.
Not sure if this matters, but I have a larger aftermarket spoiler (not OEM style like yours) on my roadster and it will stay up if I have it about 3/4 open.
Maybe since it's bigger the counterbalance lets it stay like that?
Disclaimer: I'm no rocket scientist/physicist.
Old May 22, 2015 | 07:53 PM
DeusExMaxima's Avatar
DeusExMaxima
I have the huge Nismo v3 spoiler and my trunk stays open.
Old May 28, 2015 | 09:00 PM
billydabiller's Avatar
billydabiller
I have the same spoiler. I don't know if it came with the car or not
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Li1ag
Sep 28, 2015 02:07 PM
