How to turn off airbag light
I looked under the seats and the resistors that I put in the airbag connectors had fallen off. I reinserted the resistors and tape them up really good so they will not come off. Then I reconnected the battery and put the car in airbag diagnostic mode and then took the car out of airbag diagnostic mode and the airbag light went off.
I have 2008 Nismo 350Z seats in my 2005 Roadster. The seats have airbags but the connectors are different. Does anyone have a spare set of 2005 or earlier seat airbag connectors? It would be nice to be able to utilize the seat airbags in case of the worst.
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
ashtrojan2008
Mar 23, 2010 10:02 PM
Specter Werkes
Nov 23, 2007 08:34 PM
