gas door latch
Old Oct 1, 2004 | 05:09 AM
stevez redline's Avatar
stevez redline
Default gas door latch
my gas door latch seems to stick and now wife has broken the button . has anyone had this problem
Old Oct 1, 2004 | 10:22 AM
amallari's Avatar
amallari
I've had my door latch stuck a couple of times, I think there is a TSB on it. I'm sure its covered under the warranty.
Old Oct 1, 2004 | 01:25 PM
SeanG's Avatar
SeanG
It is covered. They have a new style of metal clip that will help. They worked on mine but it still has some issue now and again.
Old Oct 1, 2004 | 09:06 PM
Beaker02's Avatar
Beaker02
They "adjust" mine all the time. It never really helps. I'm just used to pop pop pop pop pop pop popping it open at stations.
Old Oct 3, 2004 | 03:31 AM
Chief F1 Fan's Avatar
Chief F1 Fan
I thought it was something I was doing (key on or off???) but now feel better. I gotta get it fixed b/c it is drivin' me nuts. It wouldn't be so bad if the fuel door was on the driver's side.
Old Oct 3, 2004 | 08:08 AM
rjaustin's Avatar
rjaustin
Yeah I know what you mean. I feel like an idiot getting out of the car, looking at the fuel door, then walking back around to push the button again, then getting out of the car, . . . . . . . .
Old Oct 3, 2004 | 10:45 AM
ragtopz's Avatar
ragtopz
yeah, i used to walk around the car just to see that the door hadn't opened. now i press the button twice as part of the routine. seems to do the trick for now.
Old Oct 8, 2004 | 11:08 AM
thumper90501's Avatar
thumper90501
LOL...I feel like a moron too. I'm thinking of angling the side mirrors to see if I can view it from there.
Old Oct 8, 2004 | 12:34 PM
stevez redline
well glad to know that it has happened to other people as well . the dealer had to order the switch over a week ago still waiting...
but thanks for all the feed back to my question my wife and i thought we were losing our minds
Old Oct 9, 2004 | 04:21 AM
Chief F1 Fan
Still can't see it, I've tried. People see me crawlin' out of a hot car, walking around, no gas door open, walk back around, hit switch couple times, repeat. Must look like a clown who doesn't know how to work his car, drives me around the bend!!!!!!!!!!!!!
Old Oct 26, 2004 | 05:21 AM
wendyk1212's Avatar
wendyk1212
I can't seem to get mine fixed either so I simply pop, pop, pop at home and then go the gas station....got tired of being smirked at at the gas station. Ten months later....still sticking...
Old Oct 26, 2004 | 04:43 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Mine doesn't stick but it never sits flush with the body of the car. Is this one of the problems that they will fix? My production date is 7/04.
Old Oct 27, 2004 | 09:32 AM
Beaker02's Avatar
Beaker02
Mines getting bad again. I'll have it looked at on the next oil change.
Old Oct 27, 2004 | 01:08 PM
Ivey's Avatar
Ivey
There is definitely a TSB on it and a qualified dealer should be able to get it fixed with the new hardware. I had mine fixed, something to do with the actuator on the fuel door itself and now it works first try every time. It does however seem to be slightly extended when closed and stick out slightly on the bottom. I looked at a new one in the dealership and it had the same slight misalignment issue so not much you can do about it. I've also noticed several of the pictures online show the same misalignment. It's annoying but low on the list (short list) of issues needing improvement.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
