Xenarc 700v simple question
Old Mar 4, 2005 | 05:52 AM
J-04blackZ's Avatar
J-04blackZ
Default Xenarc 700v simple question
the 700v 7" monitor it has a few buttons on the bottom of it...when u install it where do those buttons go?? Do u have too take off the frame of the screen or what...check out pic's
Old Mar 4, 2005 | 05:53 AM
J-04blackZ's Avatar
J-04blackZ
Here's a pick of the install!!.....It may be a dumb question, i was just wondering...
Old Mar 4, 2005 | 07:00 AM
manofsteele2003's Avatar
manofsteele2003
Are you sure that's a Xenarc screen in that car? I have the Farenheit 7000, fits perfectly and I can just use the remote for all the screen options.
Old Mar 4, 2005 | 07:11 AM
J-04blackZ's Avatar
J-04blackZ
Yes it's the 700v....I even seen picks of 700tvs the touchscreen version and all those screens have the butttons on the bottom but when they install the screen in the consule those buttons are no longer their...where do they go?? I'm debating wether to get the 700v of 700tvs and its something thats bothering me...
Old Mar 4, 2005 | 08:31 AM
chromesilverz's Avatar
chromesilverz
You won't be able to access them unless you take off the plastic piece on the front/bottom and stick your finger under and behind it. Basically the buttons will be hidden when you install it.
I guess some custon button extension would work. But that would require some work.
Old Mar 4, 2005 | 08:54 AM
desiZ's Avatar
desiZ
you have to take the cover off... i have a 700tsv and the buttons are just below ... you cannot access them but you never need to once you have it setup the way you want... someone did a mod where they moved the buttons onto the front plate but I have never needed to use the buttons for the last 3 months...
Old Mar 4, 2005 | 09:49 AM
J-04blackZ's Avatar
J-04blackZ
DesiZ did u install everything yourself?? Was it hard?? If not how much did it cost?? Did u have to set up your screen the way you wanted it before u installed it?? Also u have a car pc installed right, how did u get the Z screen skin, was it a special program or what?? I would like to go that route and it seems that everybody is doing it, but to tell u the truth unless u have a pc laying around, it will cost some money to get one with all the programs u want...
Old Mar 4, 2005 | 10:03 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Yes you remove the outer plastic before installing.
I think most people have the newer version Xenarc with remote control that can be used to provide the functions of those buttons without using the buttons directly. I have the same issue since the screen I bought on eBay did not come with the remote. I guess I'll either have to do some custom work to move the buttons or get a different screen.
Old Mar 7, 2005 | 12:13 AM
Michla22's Avatar
Michla22
I have the touch screen xenarc - no remote...i did it this way:
I then completely took the touchsceen apart and rewired and re-arranged the boards:
I put the buttons on the side and drilled holes which aligned with the buttons/led:
until i get some plastic buttons to fit he holes i can push, i just use a small pin to hit the buttons ... i was bored.
Old Mar 7, 2005 | 05:04 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
thanks for the pics
Old Mar 7, 2005 | 06:01 AM
J-04blackZ's Avatar
J-04blackZ
Aww thanks for the pics...now i know how to do it... is the touchscreem only good if u have the car pc???
Old Mar 7, 2005 | 06:15 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Michla: Does your xenarc have a remote ? How do you deal with the loss of the buttons from the xenarc? what if you need to change the settings ?
Old Mar 7, 2005 | 04:45 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
oops, I posted before I read! how embarassing.
Thats a nice solution if you can find some buttons. Id like to see the end result.
Now, how did you attach the screen, glass, boards etc to the nav compartment ?
Old Mar 7, 2005 | 04:46 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Old Mar 7, 2005 | 05:16 PM
desiZ's Avatar
desiZ
u missed my thread a couple of months ago...
here it is
https://my350z.com/forum/showthread....hreadid=105675
Old Mar 7, 2005 | 11:13 PM
Michla22's Avatar
Michla22
yeah, read desiZ's thread , i did mine based on what i read from his thread and mp3car.com.
But in a nut shell i used double sided tape to attach the glass and screen to the plastic nav compartment..
I then used more double sided tape to attach the boards to each other the way i wanted them after extending some of the wiring. I tried to use zip ties to told the whole thing to the nav compartment but with the way i placed the boards on the back it kept making the screen crooked. I ended up tieing it with fabric to hold it in place after using the double sided tape, so far no problems.
J-04blackZ
As far as having a touchscreen, unless you needed the imput device - in this case for the pc - there wouldn't be much need for it.
Old Mar 8, 2005 | 03:49 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It isn't hard to pop out the plastic bar on the bottom and access the buttons. Just don't put the screws in and you can just pop it out without tools. I can tell you however that I have only had to do this once in two years.
http://www.350zfrenzy.com/forum/show...&threadid=1386
http://www.350zfrenzy.com/forum/show...&threadid=1403
Old Mar 8, 2005 | 04:14 AM
J-04blackZ's Avatar
J-04blackZ
Hey i even like the Alpine 5.8...but is that screen too small...It looks tight in some pics i saw...I like the Alpine across the middle of the screen when a dvd/cd is not playing... With the Xenarc is their any thing showing when theirs not a dvd/cd playing or is it just a blue screen?? I would think that the Alpine would be more of a better quality too, just cause of the name brand or am I wrong....
Old Mar 8, 2005 | 06:26 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Michla: I tried to do what you did but there was no way that the board with the buttons will reach to the side due to the length of the micro ribbon cable (unless I turn the screen upside down!). How the heck did you get it over there ?
I am considering removing the buttons from the board and wiring in extensions. I am a little concerned about trying it though!
Old Mar 11, 2005 | 11:05 PM
Michla22's Avatar
Michla22
I was looking at some pics and it looks like some of the xenarc screens come with dirrefent lengths on that flat ribbon wiring.....mine was luckly long enough...I only had to extend some of the normal wires.. the ribbon was about as far as it would strech but it worked...let me find a pic.
Hope this helps.
