How To Run Wires from Dash to Pull Out Cupholder
Old Apr 19, 2005 | 06:33 AM
Sial's Avatar
Sial
Default How To Run Wires from Dash to Pull Out Cupholder
Has anyone done this before? Any tips, guides, etc? I want to run the input for my ipod to that cupholder, but I don't know if that area is open behind it. There's not a lot of room in the dash to dig around so I thought I'd ask before I tried in case anyone has seen this done.
Thanks in advance.
Old Apr 19, 2005 | 07:55 AM
dgtlbullet's Avatar
dgtlbullet
I am also looking at doing the same thing. Anyone got any ideas????
Old Apr 24, 2005 | 02:20 PM
ZiPPys350Z's Avatar
ZiPPys350Z
Default me too
I guess nobody has any ideas for this because I would love to see some posts. I just got an iPod and wanted to run the wires to the iPod which is in the cup holder.
ZiPPy
Old Apr 24, 2005 | 02:22 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
shove your head up under the dash there and peek around... or
get a coat hanger and poke it down in there until you can tape wires to the coat hanger
Old Apr 24, 2005 | 02:31 PM
JCat's Avatar
JCat
You can remove the cupholder by inserting a screwdriver down the middle and top of it. The screwdriver basically presses on a tab that allows you to pull the whole assembly out.
There are three phillips screws that you must remove. One is in the cup holder area, and one is in the cigarette lighter area. The last screw is near the door jam. After removing the screws, the whole plastic pannel is removable. You must yank on it to pop the spring loaded rivits.
Once you remove this panel, a whole world of opportunities will present itself.
I've tapped into the lighter wiring for both my satellite radio and Escort radar detector.
Old Apr 24, 2005 | 02:43 PM
ZiPPys350Z's Avatar
ZiPPys350Z
Default thanks
Thanks for the details guys. I will have to play around and see what I can find. My main problem is trying to get the factory deck (w/o cd changer) to hook up to my iPod.
ZiPPy
Old Apr 26, 2005 | 08:13 AM
Daewoo's Avatar
Daewoo
It won't mess with the airbag stuff will it? Just making sure
Old Apr 26, 2005 | 08:45 AM
JCat's Avatar
JCat
No. Since it is the lower panel (knee level) that you are interested in removing.
I believe the air bag is under the top panel that the heating/cooling duct is in.
Old May 2, 2005 | 05:06 AM
Daewoo's Avatar
Daewoo
cool!
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
