can speaker wires run alongside RCAs without noise problems?
Old May 22, 2005 | 11:03 PM
sharingan625's Avatar
sharingan625
Default can speaker wires run alongside RCAs without noise problems?
i heard that RCAs should be seperated from the power wire to avoid engine noise and stuff. what about the speaker wires? can it run alongside RCAs or power wire?
thank you.
Old May 23, 2005 | 02:58 AM
stu46's Avatar
stu46
yes.
Old May 23, 2005 | 06:38 AM
DougJones's Avatar
DougJones
^^Ditto^^
Old May 23, 2005 | 09:10 AM
sharingan625
thank you~
Old May 23, 2005 | 12:24 PM
Beaker02's Avatar
Beaker02
Don't use cheap Chicken Shack RCA's. Make sure you have decent shielding.
Old May 23, 2005 | 02:25 PM
1qkZ's Avatar
1qkZ
The frequency for a sub amplifier is not able to be reproduced by the sub, as for high end speakers the sound is able to be reproduced through the speakers. As Beaker02 mentioned as long as you use quality RCA cables you should not have any issues. Recommended distance is 12 to 18 inches of separation between the power wire and RCA cables. As far the running power wire and speaker wire next to each other I personally have not ran across any feedback.
Julian
Old May 23, 2005 | 05:55 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The inverse square law says that for every doubling of the distance between the conductors you lower the coupling by the square. I wouldn't wire tie them together but I wouldn't worry too much unless you're running incredible amounts of power and using really bad RCA cables. Even an inch or two ought to be enough and should lower coupling to unmeasurable, let alone un-hearable, levels.
Old May 24, 2005 | 10:21 AM
sharingan625
cool. thank you very much for your info ppl~
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
