Brassy Sound
Old Jul 1, 2005 | 10:59 AM
arlingtonz's Avatar
arlingtonz
Default Brassy Sound
I have replaced the head unit with the Kenwood DDX-7015 and it seems to have quite the brassy sound with the stock speaker (I plan on swapping them out soon) but I recall seeing something about turning down the high pass filter, can anyone point me to that thread? I did a search and wasn't able to find the relevant information. TIA
Brett
Old Jul 1, 2005 | 11:55 AM
VO...'s Avatar
VO...
Administrator
Please elaborate. Give another description for "brassy sound".
Old Jul 1, 2005 | 02:26 PM
james840a's Avatar
james840a
brassy as in to much Highs range sound?
Old Jul 2, 2005 | 07:29 AM
arlingtonz's Avatar
arlingtonz
yeah, the highs seem to drown out everything else...there seems like there is little bass, and even less mids...thank you again for your help
Old Jul 2, 2005 | 08:56 AM
james840a's Avatar
james840a
Your Kenwood DDX-7015 should have some kind or treble or eq in the hea unit check the head unit manual. try adjusting the high freq. down mid range up tell it balances out, At lest tell you get new speakers and or a complete audio system.
Old Jul 5, 2005 | 11:18 AM
VO...'s Avatar
VO...
Administrator
check and see if you have a frequency attenuation option on your HU. Mine has one. If the MID or High cut off frequency is set too high, you'll heard a raspy/brassy noise from the mids. This also holds true if your HU has an amplification setting for mids/highs.. My HU has an option that will amplify the highs on the front output of the RCA's but not the rear(because rear are generally used for subs)
Old Jul 5, 2005 | 11:25 AM
onii's Avatar
onii
i just isntalled the 7015 also...and noticed that the bass is really weak. I can't access the eq settings tho..it's not selectable. Hopefully everything will be ok once i put my sub in.
Old Jul 5, 2005 | 07:08 PM
james840a's Avatar
james840a
Hows it going, any luck? i looked at a ddx7025 manual i there are eq settings and mid/hi settings and a sub setting. i didnt look into it to deep since i was at work at the time.
Just check up
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
