Where to get hardwiring for passport 8500 x50?
Old Aug 25, 2005 | 09:49 PM
thrill350z's Avatar
thrill350z
Default Where to get hardwiring for passport 8500 x50?
hey i just oredered the Escort Passport 8500 X50 Radar Detector (red) and hot the Z mirror mount and i was looking for a hardwiring kit, is there a website with one? Or should i go to my local shop and they use their own wires? Never had a radar detector before so i need some help
Old Aug 25, 2005 | 10:40 PM
Darth Bobo's Avatar
Darth Bobo
You can get some phone wire and hardwire it yourself.
Old Aug 25, 2005 | 11:14 PM
thrill350z's Avatar
thrill350z
im not skilled at electrical wat so ever, i thought there was a kit i can purchase online? or can a local shop make one?
Old Aug 27, 2005 | 10:15 AM
Darth Bobo's Avatar
Darth Bobo
Take it to a shop then. Even with the hardwire kit you'll have to tap a wire or two.
Old Aug 27, 2005 | 11:06 AM
hndumafia's Avatar
hndumafia
you can order the hardwiring kit from passport. installing it is really really easy. ive even taught a friend who has no idea how to use tools how to hardwire a radar. rather than taping any wires, it's easiest to just run the power wire back to the fuse box and wrap the end of the wire around one of the ends of a fuse (make sure it is an accessory fuse so the radar is only on when the car is on). then wrap the ground wire around a bolt that is located by the fuse box. route the wire up the a pillar, in the headliner, and bring it down to where you want the radar to be. done.
Old Aug 27, 2005 | 11:53 AM
Darth Bobo's Avatar
Darth Bobo
I just did mine, and that diagram is wrong. I had to reverse the ground and 12V for my 8500 X50 blue to power on. Other than that it was easy, took about 1/2 hour.
I tapped into the homelink mirror, black is ground and black/red is 12V battery.
Old Aug 27, 2005 | 02:15 PM
shooter82's Avatar
shooter82
i did the same thing.......i found it much easier to tap into the mirror wires......
Attached Thumbnails Where to get hardwiring for passport 8500 x50?-dsc02117.jpg   Where to get hardwiring for passport 8500 x50?-dsc02113.jpg
Old Aug 27, 2005 | 06:53 PM
R2theP's Avatar
R2theP
When I wired my last detector, I just threw a couple T-taps on the wires for the cigarette outlet for power. This worked well because the detector would turn on as soon as you turned on the ignition. I wouldnt recommend it however if you run high-amp accessories through the dash outlet, you might burn up the fuse.
Old Sep 3, 2005 | 06:05 PM
thrill350z's Avatar
thrill350z
heres how the local shop set it up for me cost like $65 with the wire
Old Sep 4, 2005 | 01:11 PM
hypeiv's Avatar
hypeiv
I had a local shop install it. They used the hardwire kit and ran it up the plastic conduit above the mirror and around to the fuse box. I think it was $50-60... I am not really a DIY kind of guy so I just threw money at the problem.
Old Sep 4, 2005 | 01:53 PM
Roger V's Avatar
Roger V
Does having it under the mirror like that obstuct the view for anyone?
Old Sep 4, 2005 | 04:21 PM
2003z's Avatar
2003z
it didn't obstruct my view, but it wasn't easy refocusing between the road ahead and the radar detector. Overall though, its still the best place to mount it.
www.escortradar.com to order the hardwire kit
haria05161
Sep 25, 2003 04:20 AM
Zyasooner
Aug 11, 2003 06:33 PM
z33boi
Jun 25, 2003 12:06 PM
scully32
Apr 25, 2003 06:14 PM
Bishop_Tx
Feb 23, 2003 09:42 PM
