Alpine bypass module?
Old Nov 1, 2005 | 12:25 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Default Alpine bypass module?
Ok, I have the bypass module that allows me to use all the advanced features/dvd while driving. I recenty took apart/re-installed the head unit/brain on my IVA-D300 and now I can no longer get to these features. I can't do the brake sequence because the necessary wires are hooked into the bypass module, which for some reason, isn't doing it's job. Is there some sort of programming process I have to complete or something?
Old Nov 1, 2005 | 01:34 PM
Blue Komodo's Avatar
Blue Komodo
I just did this with my 310. Just tie it into the wiring loom on the way to the control module. I did'nt need to tap the loom into the hand brake/foot brake at all.
Old Nov 1, 2005 | 01:53 PM
Santacruzslick
Veteran
It's already installed, but after taking apart and re-installing my system it no longer works. I'm not really sure what's going on with it. Did you have to program it or anything?
Old Nov 1, 2005 | 02:43 PM
Blue Komodo
Yeah, sorry dude. You have to pulse the brown wire twice to the ground with the switch turned on, and the ignition on. The led should flash with each pulse, then flash rapidly. Turn off the ignition, and flick the switch to off. I can fax the instructions tomorrow if you need them.
Old Nov 1, 2005 | 04:58 PM
Santacruzslick
Veteran
Thanks! I'll go try that, hopefully it'll work. *crosses fingers*
Old Nov 1, 2005 | 05:12 PM
Santacruzslick
Veteran
Ok, didn't work. :-/
Am I supposed to be doing anything with the orange wire?
Old Nov 2, 2005 | 01:18 PM
Blue Komodo
I'll quote you you the instructions when I get home. I don't remember which wires do what.
Old Nov 2, 2005 | 02:37 PM
Santacruzslick
Veteran
Awesome, thanks for the help. You're a life saver!
Old Nov 3, 2005 | 05:59 AM
Blue Komodo
OK,here are the programming instructions word for word.
1. Connect black wire to chassis ground and connect red wire to 12v accessory.
2. Slide TR-7 switch to the on position and turn the ignition on.
3. "Pulse" the brown wire 2 times and wait 3 seconds. The LED will flash 2 times for confirmation. The LED will rapidly flash for 3 seconds.
4. Slide the switch to the off position
5. Connect the green wire to the Alpine's blue/white wire, the blue wire to the Alpine's footbrake input and the white wire to the Alpines handbrake input.
Old Nov 3, 2005 | 10:18 AM
Santacruzslick
Veteran
Awesome, I'll go try it out later when I get a chance. I wonder if I have to dis-connect the wires for the brake inputs before doing this?
Old Nov 4, 2005 | 07:27 AM
NisAznMonk's Avatar
NisAznMonk
You could also look into the PAC TR-7. Used it on an Alpine IVA-D310.
Old Nov 4, 2005 | 11:04 AM
Santacruzslick
Veteran
Well, I already have the unit. I just have to re-program it. If only I weren't so damned busy.
aarrgghh
May 1, 2022 11:04 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
dcains
Nov 11, 2015 11:36 PM
Beater350z
Sep 9, 2015 03:36 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
