Installing AfterMarket HU will stock sub still work?
Old Nov 9, 2005 | 04:39 PM
gerthiekins's Avatar
gerthiekins
Default Installing AfterMarket HU will stock sub still work?
I was wondering, I am about to install an Aftermarket HU but I am not doing anything to the rest of the sound system yet, will the sub still work(bose system)? I know in some cars it won't unless u get an adapter but didn't know for sure?
Old Nov 10, 2005 | 05:21 AM
gerthiekins
ummmmmmmm is there anyone out there that can answer my ?
Old Nov 10, 2005 | 05:39 AM
Swiffer's Avatar
Swiffer
already a thread for this:
https://my350z.com/forum/audio-and-video/152411-stock-subwoofer-w-aftermarket-hu.html
Old Nov 10, 2005 | 05:40 AM
SungNamZ's Avatar
SungNamZ
All I can say is, is that Mesa Radio installed an Eclipse AVX2494 in my 2003 "Tour" yesterday using two kits from www.peripheralelectronics.com "The Key To O.E.M." Integration and my Bose system has never sounded this good! Check out thread on Mesa Radio install with pics.
Old Nov 10, 2005 | 07:46 AM
gerthiekins
camaro194 that thread does not answer my ? at all.
Sung your answer does not answer my question either.
Old Nov 10, 2005 | 10:43 AM
SungNamZ's Avatar
SungNamZ
Then apparently I do not understand your question. Go to: www.eclipse-web.com and look at the AVX2494. They have other HU besides the AVX2494. Mesa Radio replaced everything in the dash with this HU to include a couple of parts from www.peripheralelectronics.com (SVEN4 and SVHNI2). I did all this because the Nissan dealer here in Albuquerque currently has on order/backorder the 4th 6CD unit for my Bose system.
My Bose no longer Blows!
Old Nov 10, 2005 | 08:53 PM
jdg345's Avatar
jdg345
Cool! What's a differential signal though? I want to change out my HU and all my existing speakers with the exception of the sub (that's next, but probably a few weeks after I do everything else) ... my plan was to keep the sub and use it; as crappy as it might be, it's better than nothing I would think?
And Camaro, I think I started that thread you linked to ... the answer appears to be yes, but the link provided for that additional stuff appears to answer how ... wish I understood this differential stuff though? I thought that the stock HU basically ran signals to two amps. One amp ran the factory speakers, and the other ran the bose sub. There was a crossover somewhere that sends the base to the sub and the mids and highs to the front and rears ... apparently, it's not like that though as someone posted that the speaker wires for the fronts and rears are somehow connected to the sub amp? I guess if you want to change your factory setup you need to change out your existing speaker wires? Which is apparently a big pain in the butt due to the harnesses in the doors?
Old Nov 11, 2005 | 05:03 AM
gerthiekins
nevermind on the ? I am just leaving it out and selling it like i planned that way i can do my in car pc with touchscreen and while i do that i am just revamping the entire system.
Old Nov 11, 2005 | 07:08 AM
Swiffer's Avatar
Swiffer
Just did some searching and found that you will need to get a metra wiring harness if you want to use the bose speakers with an aftermarked headunit. Good luck!
https://my350z.com/forum/audio-and-video/24674-after-market-wiring-harness-for-bose-touring-system.html
Old Nov 11, 2005 | 11:06 AM
SungNamZ's Avatar
SungNamZ
https://my350z.com/forum/showthread.php?t=24674
True, but but in addition to the harness, you might also want to get: "Premiun 4ch Adjustable Line Output Converter" part# SVEN4 from: wwwperipheralelectronics.com They also have a "harness" part# SVHNI2, but you can get it from Crutchfield.
I am not an electronics guy, but in addition to the harness was told it was also needed to make the Bose work. Wish I had done this a year ago!
Old Nov 11, 2005 | 06:11 PM
jdg345's Avatar
jdg345
I just wanted to get the sub to work ... didn't really care about the other stuff since I hope to replace it all ...
m_0g
Jun 3, 2021 10:05 AM
Dr.Paulyy
Jul 29, 2019 07:45 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Paul.
Oct 16, 2015 07:34 PM
Shane86
Sep 17, 2015 05:33 PM
