Airbag Light Reset ... Dealer Wants to Charge ??
Old Jan 4, 2006 | 08:35 AM
jdg345's Avatar
jdg345
Default Airbag Light Reset ... Dealer Wants to Charge ??
Hey all, Happy New Year!
I'm in need of a little advice ... I called the Dealer to go in and schedule an Oil & Filter Change -- it's free. I figured that while I was there, I'd have them reset their airbag light that came on after I had the passenger seat pulled out to get into the rear cubby a little easier.
They said they could do it, but there would be a $80 charge to reset the system. Because the 'Whole System Needs to be Reset'. Do I really need to pay someone $80 to plug a wire in and press 'Clear' ?
Thanks!
Old Jan 4, 2006 | 08:47 AM
Mike Wazowski's Avatar
Mike Wazowski
well, you should have removed you key before taking the seat out. What do you expect? They should fix your mistakes for free? They do run a business after all.
Old Jan 4, 2006 | 09:00 AM
jdg345's Avatar
jdg345
Battery was Disconnected and no key was in the ignition when the seat was taken out. I can't remember if we tested the cable connections while the seat was still out.
To confirm, this only occurs when the seat is disconnected and the ignition is switched to On?
Old Jan 4, 2006 | 09:01 AM
jdg345's Avatar
jdg345
And yes, I think they should fix this for free since it's a matter of hooking up a wire and pressing clear. I could do it myself if I had the right computer. So ... next question ... anyone have a brand/model of Diag Computer that will reset this for me?
Old Jan 4, 2006 | 09:02 AM
Mike Wazowski
Yes. If your battery was disconnected. This never should have been a problem.
There is a TSB on the side air bag module have the dealer check on that. I had both of mine replaced due to that TSB.
Old Jan 4, 2006 | 09:04 AM
Mike Wazowski
The Nissan console II is the computer you need to reset the airbag light (not available at Pep Boys)
Old Jan 4, 2006 | 10:00 AM
disturbed2483's Avatar
disturbed2483
here you go i used and it worked.
Originally Posted by raceboy
Real easy.
Insert key turn to on position for 7 seconds. At 7th second, airbag light will start to blink, turn to off immediately within 1 second. Wait 10 seconds and repeat. Repeat a total of 4 times.
Old Jan 4, 2006 | 11:03 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I've had my passenger's seat in and out with and without the key on and with and without the battery connect. I had no warning lights. The reset shown above is a good thing to cut-n-paste into my scrap book of tips.
Old Jan 4, 2006 | 02:46 PM
jdg345's Avatar
jdg345
I gave this a shot -- just turned the ignition to on (didn't actually start the car) ... waited 10s between retries and did it 4 times ... no go ... airbag light still blinks ...
Anyone have that TSB Number?
Old Jan 5, 2006 | 07:09 AM
jdg345's Avatar
jdg345
Tried it again this morning and it looks like it worked! I'll drive around some today hopefully and make sure it doesn't come back on ... THANKS!!
btw, I kept meaning to ask ... How did you find this little tidbit?
Old Jan 5, 2006 | 10:17 AM
disturbed2483
not to sound like an *** but search actually works, i just hate saying that cause we are supposed to be here to help each other.
Old Jan 28, 2006 | 09:17 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
just wanted to type a quick thank you to raceboy for posting that procedure. Even though the battery was disconnected and key was out, I had the light after the JDM NISMO (airbag equipped) steering wheel install - this got rid of it
adam
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
