Questions about running 2 head units
Old Feb 27, 2006 | 07:13 AM
Anomaly460's Avatar
Anomaly460
Default Questions about running 2 head units
is it possible to run 2 head units in a way similar to how computers with multiple cd drives have the master/slave setting? I want to run one head unit as my main (MEX-R5)...then i want to have a second (plays MDs) wired kinda like an auxiliary unit and controlled by the main HU. Both are sony... Id also want to throw a XM radio in the mix and have it wired to the main HU. Would this be possible? TIA for the input.
Old Feb 27, 2006 | 10:09 AM
dark_muppet's Avatar
dark_muppet
yeah it'd be easy. The MEX-R5 has an aux input so just plug the output from the second HU into it. Then audio from the second one will be selectable from the AUX setting on the MEX-R5. The only problem would be powering it. I wouldn't recommend just splicing the accessory and constant power wires, 'cause that'd probably overload it. You'll probably have to tap a different accessory wire and add a fuse.
Old Feb 27, 2006 | 10:53 AM
sq40's Avatar
sq40
Agree with above.
Best route would be to have a nice HU with an Aux Input and buy an External MD player that can tuck away when not in use like an Ipod does.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
cashmoney03
Sep 27, 2015 05:24 PM
bryanlam199
Sep 24, 2015 04:04 PM
