Bose Wiring / Pinout Diagram
Old May 18, 2006 | 05:07 AM
Derek's Avatar
Derek
Default Bose Wiring / Pinout Diagram
Does anyone have a wiring & pinout diagram for the Factory Bose system? I've looked everywhere!
I'm going to be keeping my factory HU for a while, but I want to go ahead and replace the factory amps and speakers... so, for the short term, I've got a bit of Bose integration to deal with.
Old May 18, 2006 | 05:20 AM
w8lifter21's Avatar
w8lifter21
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Notes: If equipped, the amplifier is on the driver side of the trunk.
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
Notes: Also white - black on some models.
RF Speaker +/- yellow/red - red/white +,- radio harness
Notes: Also green - red on some models.
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
Notes: Also brown - black/red on some models.
RR Speaker +/- blue/orange - black/pink +,- radio harness
Notes: Also blue - pink on some models.
Old May 18, 2006 | 05:42 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Except the service manual and the posts pinned to the top of this forum.
Old May 18, 2006 | 08:18 AM
Derek's Avatar
Derek
Is the service manual available online?
I've got the color code charts, I was more looking for a schematic that showed the pin locations on the connectors (which I can always reverse engineer) and showed the interaction with other circuits in the car. I'm guessing the Bose system is fairly isolated from the rest of the car's electrical system. I just hate to tap a circuit and then get some unexpected behavior because I didn't see the big picture.
Old May 18, 2006 | 12:45 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
That's where I found it. I don't have a copy posted on-line. Someone might give you a link if they're kind enough.
Old May 27, 2006 | 03:04 AM
boost777's Avatar
boost777
i found it here by searching and its on the other 350 sites as well
Old May 27, 2006 | 09:12 AM
Derek's Avatar
Derek
I pulled the trim out of the hatch area today to get a look at the Bose amp. The Sirius Satellite Radio module is mounted above the amp. It is interesting to note that there is an unused connector on the sirius module. I suppose its there so other devices can be "daisy chained" to the aux input bus (According to PAC, the HU can support two additional aux inputs). Also the antenna amplifier is located to the left of the amp mounted higher up. There is (what looks like) a standard motorola antenna connector between the actual antenna itself and the amplifier - theoretically you could use that to connect to an aftermarket HU if you don't want to fool with getting the Nissan antenna adapter. Two wires (shielded cables?) leave the antenna module and connect to the HU.
If anyone is interested, let me know and I'll post some pix that you can print out and throw darts at.
Old Mar 22, 2012 | 01:45 PM
rmadden5925's Avatar
rmadden5925
new to forum i pulled pin out of stock bose unit in rush need to know were they go back in please
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
