Tweeter help no sound coming through =(
Old May 25, 2006 | 02:32 PM
350ztoronto's Avatar
350ztoronto
Default Tweeter help no sound coming through =(
hi im currently doing my tweeters i got my components to work but not my tweeters i gutted the entire bose system out, and i read just about every 'tweeter' thread there is on this site and i am now totally stumped =(
i have jl xr650 components and they come with tweeters
i first tried to test out the tweeters by using the front left + - from the head unit into the input in my crossover then output into my tweeters
btw if it matters i spiced the wires for my tweeters there are no plugs like the stock on just wires, anyways this attempt failed i got nothing
second try, i read on another thread that i needed to tap into the stock tweeter wire and put that into the input tweeter then output it into my new tweeters again i got nothing
can anyone help me? thx
Old May 25, 2006 | 05:04 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Sounds like the tweets are blown already.
If you have an ohm meter put it on the 1X setting and read the resistance across the coil. A blown tweeter would read infinite.
Old May 25, 2006 | 05:08 PM
350ztoronto
i dunno if they are blown they brand new and my stocks were working fine before i install the new system and i plugged them in and no go
Old May 25, 2006 | 07:25 PM
JimRHIT's Avatar
JimRHIT
did they make a little blip of sound when you first plugged them in ... like just for a millisecond and then stopped?
Old May 25, 2006 | 07:38 PM
350ztoronto
didn't turn on whatsoever, i plugged in the stock tweeter and again nothing, i think it might have been the HU wiring but i checked that and again nothing frick i am so depressed the component speakers work but the easiest thing i can't get
Old May 25, 2006 | 07:46 PM
JimRHIT's Avatar
JimRHIT
do you have sound from the midbass speakers?
Old May 25, 2006 | 07:51 PM
350ztoronto
yup i can get my midbass speakers (component speakers) to work but both my tweeters are not working
Old May 25, 2006 | 08:02 PM
JimRHIT's Avatar
JimRHIT
hmmm ....
heres my idea of how you set it up.
........................................ ======= tweeter
Head Unit ====== crossover //
........................................ \\=========== midbass
is that correct?
hmmm ... that sure as hell didnt work lol
ok .. kinda fixed it ... you get the idea
Old May 25, 2006 | 08:06 PM
350ztoronto
kinda like that, but i will amping the components i just did that kinda setup to test the speakers to see if they worked and the crossover is the one that comes with my speakers i have 4 one for each speaker
Old May 26, 2006 | 12:14 AM
350ztoronto
do i input the stock wires into the input crossover? it says on it "not in use"
wierd, thats what i've been doing maybe i shouldn't put the tweeters in the crossovers? i'll try that
Old May 26, 2006 | 11:25 PM
350ztoronto
ok, so i got the tweeters to work i put the head unit wiring front left + - to the tweeters without wiring them to the crossover so i guess i found the problem -_-! thx for everyones help
i hope this works
Obadabot
Jun 18, 2023 11:31 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
