Help: running wire from the battery
Old Jun 11, 2006 | 11:37 PM
350ztoronto's Avatar
350ztoronto
Default Help: running wire from the battery
hi all im using the JL 2gauge to 2 4 guage wiring kit (2 amps)
it came with 20 feet of 2gauge and a main fuse on one end the other end was a ring terminal for connecting to the positive battery do i just cut the 2g wire connect it to the main fuse and the run more 2g wire from the other end of the fuse to a distributer
it came with 10 feet of red 4g wire and 10 feet of 4g black wire it said that the black one had a bolt on master ground lug for secure ground connection and the other end had a 5/16 ring terminal if that is the case my black wire is for grounding then what wire am i going to use for my other amp?!?! =(
heres the kit if anyone wants to help
http://cgi.ebay.com/JL-Audio-XA-PCS2...QQcmdZViewItem
Old Jun 12, 2006 | 12:16 PM
VO...'s Avatar
VO...
Administrator
yes
Cut the 4g black wire in half. This will give you 2 peices of 5ft grounding cable. Buy another ring terminal(aka=eyelet) and crimp it to the end of the new piece of wire. Now you have 2 grounding cables, one for each amp. A 5ft grounding cable is plenty long enough. If you need to run you grounding cable longer than 5ft, then you need to reconsider where you're grounding it at.
Old Jun 12, 2006 | 04:23 PM
350ztoronto
thx vo u always come in the right time ^_^
Old Jun 13, 2006 | 08:50 AM
VO...'s Avatar
VO...
Administrator
No prob
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
