Car wont start help diagnose
Old Jun 20, 2006 | 04:03 PM
350ztoronto's Avatar
350ztoronto
Default Car wont start help diagnose
so about 6 weeks ago i started my audio system install which has been totally laggin due to work, the car hasn't been turned on since then the power has been since i have been working on the audio system putting back the negative wire to check if certian things were wired properly, now amost complete my system would only turn on with amps for like 10 minutes when fresh but when i try again it plays for only 30 seconds and now MY CAR WONT START
arghhh!!!!!! help
so do i need a jump?
Old Jun 20, 2006 | 04:40 PM
350ztoronto
bump bump bump
16psibrick's Avatar
16psibrick
Simplicity in Sound
man, i been following your posts and you really should have taken it to a good shop...no amount of savings is worth all that trouble, good luck! check if you popped any fuses anywhere
b
Old Jun 20, 2006 | 05:05 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Ah, yes.
Old Jun 20, 2006 | 05:10 PM
350ztoronto
yea man i know dude i do wish i had brought it to a shop but i wanted to learn -_-!!
Old Jun 21, 2006 | 03:46 PM
KPierson's Avatar
KPierson
Sounds like a dead battery.
Old Jun 21, 2006 | 10:58 PM
350ztoronto
hope not car isn't even 1 year old =/
Old Jun 22, 2006 | 04:54 AM
KPierson's Avatar
KPierson
First, when I said 'dead' I simply meant it needed to be charged. But, you bring up another point. Once a battery sits long enough to completely drain itself it will never operate at its maximum capability again. Completely draining a battery is referred to as 'deep cycling' the battery, and a deep cycled battery will never have the storage capacity that it did before the deep cycling.
My car, an '04 G35 with 14K miles on it is on its 2nd battery due to the fact that the car sits in shops for extended periods, and it set without a motor in it for three months. The stock battery is weak compared to the red top Optima I have now!
So, if you spent 6 weeks working on your stereo, and you were using the battery to test it, without ever actually starting the car, and you were listening to it until the battery died (like it sounds like you were) it is very likely that the battery does in fact need to be replaced. Not because of a quality problem with the battery, but because the battery was not taken care of by the owner.
Old Jun 22, 2006 | 08:46 PM
Derek's Avatar
Derek
This is totally out of left field but if you have the white A/C control module under the HU disconnected the car will turn over but not start (And your check engine light will be activated). I learned this the hard way.
Old Jun 28, 2006 | 02:00 PM
350ztoronto
cool thx for everyones help i jumped the car it works now -_-
Chris350z03
Oct 8, 2023 07:19 PM
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
