Change original spk.
Old Feb 25, 2003 | 04:20 PM
Dany R1's Avatar
Dany R1
Question Change original spk.
Does somebody who have to change only the stock speakers and keeping BOSE amplifier and BOSE HU ???? So yes what a mark have to be used number of model if possible would be a aprecier!!! How many HOMS for front and the rear speakers ?? Thanks
Old Feb 25, 2003 | 11:12 PM
Jason's Avatar
Jason
Your first language must be French?
I think your questions are: Can you change the speakers and keep the Bose amp and HU? How many ohms are the speakers?
I don't have a Bose system myself, but I believe they use the same speakers (minus the sub) as the standard system. In that case you should be able to change just the speakers.
In the Z, the front speakers are 8 ohms and the rears are 32 ohms. Basically any speakers you buy aftermarket will be 8 ohms. That just means the rear speakers will be louder than stock and you'll have to fade the sound forward.
Old Feb 26, 2003 | 03:33 AM
onecoolee's Avatar
onecoolee
Jason, not true...
Most aftermarket speakers have an impedance of 4 ohms, and not 8 ohms. The Z's front, I believe, is 4 ohms, and rear is 32 ohms...just to clarify.
Old Feb 26, 2003 | 04:25 AM
kbsig106's Avatar
kbsig106
Default Pic of Org. front speakers
Does anyone have a pic of the front speakers to confirm the ohm rating?
Thanx
Old Feb 26, 2003 | 04:33 AM
onecoolee's Avatar
onecoolee
I have all 5 factory Bose/Clarion speakers sitting in a box in my basement...I can check the rating on them when I get home, if no one repsonds before then...
Old Feb 26, 2003 | 05:10 AM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Default Re: Pic of Org. front speakers
Thanx
I'm pretty sure that you are referring to the Bose speakers but in case anyone else stumbled across this thread and was curious about the "stock" speakers here's a picture of them (they are 4 ohms and real crap-note the factory grill is only 2/3 perforated!)
Old Feb 26, 2003 | 05:38 AM
kbsig106's Avatar
kbsig106
Default Thanks for the pic
I have noticed (myself included) that there are a growing number of people that want to keep the Bose HU in place. I myself have the factory NAV and don't want to go around my elbow just to put in a new HU/AMP/SPEAKERS and a single speaker for the NAV voice. It's just way too much overkill for me at "this" time.
I think where we're trying to go with this, as we would see at least a quality up-grade from the stock speakers. If the front set ( 3/4" tweeter and 6 1/2" woofer are 4 ohm, then we could reaplce the 4 speakers with little or no effort. All the while we keep the factory cross-over and just swap out the speakers. In regards to the back set, well if they're 32 ohm - I'll just keep them in place. The sub, if it can be replaced as easy as the front 4 then it's on the block also.
It may not be the cure all to the bose problem, but it will at least give some level of happiness knowing that you have done some impovements to help yuo get over the sorry HU.
My desire is to replace the speakers that can be replaced with little or no effort and I would also like to add XM radio to the Bose HU. Once I've done that, I'm pretty happy for the time being - as the months go by who knows - more info will be out there.
Thanks for all the help - we're getting there.
Old Feb 26, 2003 | 08:33 AM
TIMMY's Avatar
TIMMY
Will 6 3/4 speakers fit behind the seats?
Old Feb 26, 2003 | 08:45 AM
onecoolee's Avatar
onecoolee
Default Probably not...
Unless you want to use your hacksaw...
The factory speakers are 6 1/2", and I htink anything larger width-wise would probably not fit in the rear factory locations. There is a good chance they would fit up front since you have to make a spacer ring anyways to hold any upgrades in the front doors.
Old Feb 26, 2003 | 08:48 AM
TIMMY's Avatar
TIMMY
Thanks for your help
Old Feb 26, 2003 | 09:04 PM
Jason's Avatar
Jason
Originally posted by onecoolee
Jason, not true...
You're right. My mistake, don't know what I was thinking
Old Feb 27, 2003 | 10:31 AM
noahbuddy's Avatar
noahbuddy
I just ordered the Rockford Fosgate FNQ3146 to replace the 6 stock speakers. When they arrive and I get them installed, I'll let you know if it makes any difference.
For now I plan on keeping the stock hu, amp, and sub.
If it doesn't sound "excellent" I'll probably get a 5 channel
amp with speaker level inputs to replace the blose amp.
Next I'll change the sub.
And if it still sucks, then I'll replace the HU or get an EQ to
tweek the missing frequencies.
I also plan on using something like this software:
http://audio.rightmark.org/
to get a more quantitative analysis of the improvements.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
