Tapping power from my homelink to Passport
Old Aug 19, 2006 | 12:34 PM
Nexx's Avatar
Nexx
Default Tapping power from my homelink to Passport
Just received one of Mike's mounts for my Passport 8500. Now I need to figure out how to tap the power from my homelink to it. I know I'll need an RJ11 cable to splice into the homelink power wire. Just not sure how to do this exactly. What color are the power wires? Any suggestions would be welcome.
Thanks!
Old Aug 19, 2006 | 05:45 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
In the car prior to the jack:
Red/White = Battery
Green/Yellow= Ignition
In the mirror itself:
Black/Orange = Battery
Black/Red = Ignition
Black = Ground
Old Aug 19, 2006 | 05:54 PM
Nexx's Avatar
Nexx
thanks! after about an hour of searching i finally found the thread i needed. sounds like a pain in the **** cause the wires are so thin but we shall see.
Old Aug 20, 2006 | 03:29 PM
wahooj's Avatar
wahooj
You can also try this: http://www.invisicord.com/
Haven't tried it myself, but its on my to-do list to order one.
Old Aug 20, 2006 | 03:49 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Seems like a safer method
Old Aug 20, 2006 | 09:39 PM
Nexx's Avatar
Nexx
sigh, im a sucker for easier methods. just ordered one of those "invisicords" looks like a cleaner safe method. worth a few bucks to me.
Old Aug 20, 2006 | 09:50 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Nexx let us know how the results are since I just ordered Mike's Mount but waiting on either the invisicords or doing the hardwire myself.
Old Aug 20, 2006 | 10:19 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
how long did it take you guys to get the mount from mike?
Old Aug 21, 2006 | 06:22 AM
bdmpastx's Avatar
bdmpastx
Invisicord...what a joke...I cannot beleive that people pay that much for a phone cord with pins on it.
Old Aug 21, 2006 | 08:17 AM
Nexx's Avatar
Nexx
no problem. i will let you know how it goes.
Old Aug 21, 2006 | 08:25 AM
Nexx's Avatar
Nexx
we do cause some people would rather not bother with splicing or rigging their own pins. to most of us, $15 is change found between the cushions of our couches.
Old Aug 21, 2006 | 12:09 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
I have to agree some of us are not electrically inclined to start cutting wires but ask me to do install mechanical mods and I will do.
Old Aug 28, 2006 | 12:53 PM
Nexx's Avatar
Nexx
update: go the invisicord. must say, this is the most stoudt RJ11 cable ive ever seen. wires are nice and thick and the black color blends in with the mirror making it as stealthy as possible install was a friggin breeze. remove the cable from the mirror. stick the two invisicord pins into proper pin placements in the power cable. plug it back into mirror, use the zip tie they provide to neatly tie the cabling together. turn the car on and test. took a whole 3 minutes. i would highly recommend this product. its nice clean, easy install with no cutting involved.
Old Aug 28, 2006 | 05:42 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
awesome Nexx thanks for the review...
Old Aug 29, 2006 | 06:40 AM
Brocken's Avatar
Brocken
I was very leary of splicing into the homelink wiring on my Z so I just ran the wire from the fuse box. It was pretty easy getting into the fuse box and doing an "add a fuse". Then I just ran the wire around the trim.
The fuse box is by your left foot. If you remove the kick panel trim it's right there.
Old Aug 29, 2006 | 08:15 PM
wahooj's Avatar
wahooj
Thanks Nexx!
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
