Advice for My Set Up / Ground Wire Kit
Old Aug 30, 2006 | 05:09 PM
dro916's Avatar
dro916
Default Advice for My Set Up / Ground Wire Kit
Hello all, I've been piecing my system for the past 2-3 weeks and so far I have:
  • Alpine IVA-W200
  • JL 10W7 w/Enclosure
  • JL 500/1 Amp
  • 8 Guage Wires
  • Metra #99-7402 Dash Kit
I was going to get a capacitor, but I've read on www.the12volt.com that it is basically a waste of money.
I've decided to upgrade what they call "The Big Three" instead.
I might start with the custom Ground Kit for our cars that a member on the boards is selling. Does anyone have any experience or feedback with this?
Do you guys think I might need something else for my system? I'm not going competition bass since we tested the 10W7 and it pretty much shook the whole garage already. I just want to make sure I will be okay with this setup.
Any advice or tips will help! Thanks!
More info about "The Big Three" here:
http://www.the12volt.com/installbay/...TID=73496&PN=1
Old Aug 30, 2006 | 05:34 PM
momo 350z's Avatar
momo 350z
good list so far..but with that much bass.your going to need something upfront to compnsate for that much bass..some after market comps with a nice 2 channel amp should do the trick..
Old Aug 30, 2006 | 08:48 PM
Ryan5508's Avatar
Ryan5508
Im doing amost the same set up currently
10w7 in custom box
JL 500/1 amp
JL VR650-CSi (front)
JL VR650-CXi (back)
JL 300/4 amp
Pioneer premier DEH-P880PRS (ipod adapter + pac)
I currently have everything but the sub and the driver door speaker in place. should have time to finish it friday hopefully. Just need that damn dash kit to come in so I can put the radio in place. Its hanging there basicaly. Cant wait to hear it.
I also woundnt mess with a capacitor unless you notice a proble after its all installed. I doubt you will need one anyways.
Old Aug 31, 2006 | 06:18 AM
dro916's Avatar
dro916
Cool thanks all!
10w7 in custom box
JL 500/1 amp
JL VR650-CXi (back)
JL 300/4 amp
How much did the JL VR650-CSi and JL VR650-CXi run you? Do you think I can run those off the IVA-W200?
One of the only problems I have now is to try and bypass the video lock on the IVA-W200. I was thinking of trying to make my own switch, but the PAC TR-7 seems to be a lot easier (at a rediculous price though @ $30).
Old Aug 31, 2006 | 07:00 AM
Anu2g's Avatar
Anu2g
I have the TR-7, its easy to install and its 20 bucks online. It just takes a few min to install.
The comps won't sound even close to as good running off the w200 as they would on an aftermarket amp. I guess for the mean time, it'll suffice, but it'll prolly distort at loud volumes.
Old Aug 31, 2006 | 07:09 AM
Anu2g's Avatar
Anu2g
i meant to say it just take a little while to program.
Old Aug 31, 2006 | 02:16 PM
Ryan5508's Avatar
Ryan5508
I purchaced both sets of speakers (JL VR650-CSi and JL VR650-CXi) for around $400.00
Old Aug 31, 2006 | 02:25 PM
StreetOC192's Avatar
StreetOC192
You will definitely need a set of nice components up front. my opinion though is to spend as much as you can on NICE components for the front. Eliminate the rears altogether (they are for fill anyway and there are no back seat passengers in the Z). You truly won't miss them. Run them off the head for now if $$$ is tight, but plan on getting a 2 ch amp for the components in the near future.
As for the big 3, that is perfect. you really don't need a grounding wire kit. just get some 4awg wire and some rings and run your own. Capacitors are a waste if you are not going into competition level sound systems. Even then there is some debate if they really do anything.
On a side note, i hope you plan on installing some sound damping material throughout the Z. The JL sub is going to shake a few things loose. I have used FatMat on my last 6 installs and have been super happy with the results. It's cheaper than dynamat and easier to work with, doesn't stink nearly as much, doesn't run in high heat, etc.
Old Sep 1, 2006 | 10:17 AM
maturola's Avatar
maturola
10w7 in custom box
JL 500/1 amp
JL VR650-CXi (back)
JL 300/4 amp
Nice setup, I have a similar setup just that instead the 10W7 I have 2 10W6s and my Head Unit is the Avic-z1.
I agree that you will need nice Spk at front. you culd run them easy with your head unit, but it will really worth to get a 2 Channel amp for them, It will sound much better since you already have a nice setup it will really worth to get the extra amp.
Check out PICs of my install JL SYSTEM
You could also get a 4 Channel amp and moe the rear speaker also, but as many people have said, they are really no needed. You DON:T need any grounding ket, I use 2 g Wire for Power and Grounding, and replace the Ground of the battery. Don;t make GND wire of the Amps too long and you'll be fine.
You will need to Dynamat (or similar product) the whole card, Doors and all areas you can, that much bass you rattles your car like crazy.
Another note you will need at lease 1.25'' Spacer at the door (unless you are using Doorpods, I wanted a stock look so i went with the spacer). a 1'' will no do it.
liqalu04
Jan 2, 2022 12:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
