Turn signals work but dash doesn't display
Old Sep 16, 2006 | 01:11 AM
M3to350z's Avatar
M3to350z
Default Turn signals work but dash doesn't display
I checked all my fuses inside the cabin and under the hood and I can't seem to find out why I my dash does not display the turn signals.
To further explain, my turn signals do work but the dash does not display the turn signals if they'r working.
I don't even here a relay working....
Old Sep 16, 2006 | 01:58 AM
kourosH's Avatar
kourosH
dealership
Old Sep 16, 2006 | 02:16 AM
NewJerZ's Avatar
NewJerZ
+1 I doubt this is a do-it-yourself type thing. Good luck
Old Sep 16, 2006 | 03:35 AM
bleufiend's Avatar
bleufiend
Just throwing a dart in the dark here to maybe help you but it is possible that your dimmer switch for your dashlights has taken a crap.
Old Sep 16, 2006 | 03:47 AM
NewJerZ's Avatar
NewJerZ
Wouldn't that affect ALL of the interior dash display items (NOT just the turn signals)?
BUT maybe a seperate relay for the turn signal that feeds off of the dimmer switch is faulty??
In any event, see your dealer....
I've never had this happen...not even in the POS Pontiac Fiero I owned...Just little stuff like rebuilt tranny and rebuilt engine...yeesh!
Old Sep 16, 2006 | 10:57 AM
Mang's Avatar
Mang
Does the dash display when you acitvate the Hazard switch ?
Old Sep 16, 2006 | 04:53 PM
maxpowers's Avatar
maxpowers
Never heard of this one. Sometimes my tick sound doesn't happen but the light always comes on.
Old Sep 18, 2006 | 09:02 AM
M3to350z's Avatar
M3to350z
same goes for hazard light button. Lights are on but no dash. I will mess with the dimmer. Never thought of that.
Old Sep 18, 2006 | 12:27 PM
elidoc's Avatar
elidoc
Same thing happened to me, the head tech had it for three days and finally found a loose wire. No charge and dealer paid for a rental.
Old Sep 18, 2006 | 12:38 PM
Mang's Avatar
Mang
Power wire to the dash lights, its not in the dimmer, because the indicator lamps are not in the circuit.
Because both dash indicators are off, even with hazard check earth of flasher relay circuit.
Old Sep 25, 2006 | 11:07 AM
Tri-GunSlingEr's Avatar
Tri-GunSlingEr
The EXACT same thing just happened to me after switching out my headunit. Do you think I knocked a wire loose or something? Hey Mang where would I check for those wires at. Thanks!
Old Sep 25, 2006 | 11:20 AM
M3to350z's Avatar
M3to350z
Where was the loose wire?
Behind the gauge cluster or under the dash or even next to a fuse box?
It could take me hours if not days to find this loose wire.
M3to350z's Avatar
M3to350z
p.s. its quite embarrasing leaving your turn signal on for 5 miles!
Old Sep 25, 2006 | 11:26 AM
Mazinger Z's Avatar
Mazinger Z
Maybe a blown fuse? Check your manual, it should say which one.
Old Sep 25, 2006 | 11:38 AM
M3to350z's Avatar
M3to350z
The fuses are all fine, inside and out.
Old Sep 25, 2006 | 01:45 PM
Tri-GunSlingEr
Same here, all fuses are fine and blinkers work great you just cant tell that there on from inside the car. lol. My headlight doesnt beep when I turn my car off anymore either. All this after a simple deck swap WTF?
Old Sep 25, 2006 | 01:48 PM
M3to350z's Avatar
M3to350z
same here with that head light beep. Our head lights should turn off anyways. POS
Workshop12
Mar 23, 2020 01:45 PM
Vigman
Nov 17, 2015 04:34 AM
Shane86
Sep 17, 2015 05:33 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
Daniel_dh
Sep 7, 2015 12:56 PM
