How to Remove
Old Sep 30, 2006 | 08:01 PM
freemanjc's Avatar
freemanjc
Default How to Remove
Does anyone here know how to remove the "10" speaker bracket behind the driver seat. I was going to build my amp rack and put in there but can't get in there since there is a 10inch metal bracket that I am unable how to remove! Does the plastic pop off or do I have to pop off something else before that front plastic piece comes off!
R,
Free
Old Sep 30, 2006 | 08:19 PM
first350's Avatar
first350
you'll need to take off the plastic peice that runs from the passenger side to driver's side...after that peice comes off, you'll see ~10 screws holding it on. (I forget what else you have to take off...yuo might need to pop off the side plastic peices around the upper seat belt retractors).
-Peter
this thread shows how to remove the rear speakers plastic...not exaclty what you're looking for, but in the same area.
https://my350z.com/forum/showthread....threadid=26837
Old Sep 30, 2006 | 11:57 PM
hndumafia's Avatar
hndumafia
you will need to remove the plastic pieces that run up by the seat belt. then you will have to remove the screw that hold the rear part of the center console (so you can lift that rear part up). then you will need to remove the plastic panel that goes from the drivers side to the passenger side. the bolts that hold the sub woofer panel will then be exposed and easy to remove. it's all easy to do.
Old Oct 2, 2006 | 06:39 AM
tienlo's Avatar
tienlo
it should look something like this.
My car, my back garden.
Attached Thumbnails How to Remove-photos-27-01-2006-135.jpg   How to Remove-photos-27-01-2006-136.jpg   How to Remove-photos-27-01-2006-139.jpg
Old Oct 2, 2006 | 10:34 AM
240Zplus110's Avatar
240Zplus110
Good on ya!
Hope it all goes back together and you're not left with some extra screws
Are you dynomatting the whole car.. or ??
Old Oct 3, 2006 | 11:56 AM
VO...'s Avatar
VO...
Administrator
^^ Can anyone find Waldo?
Old Oct 24, 2006 | 09:38 PM
Machupo's Avatar
Machupo
wow!!! got any more photos of the cubby-spaces / back of the car? I'm looking for just about everything you can give me from any angle behind the seats, both in front and behind the strut bar. I'm going to be doing the same thing this winter, but want to plan it out a bit before I have the car in a similar state of disarray
edit: also, did you use the shop manual to get to this level of disassembly or some other source?
Old Oct 24, 2006 | 10:15 PM
hndumafia's Avatar
hndumafia
you shouldn't really need a shop manual.. just start pulling pieces off, and before you know it it'll look like his yard. everything comes out pretty easily.
Old Oct 25, 2006 | 06:06 AM
Machupo's Avatar
Machupo
Cool -- I took advantage of having an enterprise-sized printer a couple years ago and printed out the entire shop manual for the '03 Z
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
