Help with HU installation: No sound at all
Old Nov 10, 2006 | 05:25 PM
hiimwayne's Avatar
hiimwayne
Newbie
Default Help with HU installation: No sound at all
So today was my first time attempting to install an aftermarket headunit. It's a Kenwood DDX-7017 which I bought from another member. The previous owner had the unit installed professional at an authorized retailer and comes with all the wiring harness. I plugged the 2 wiring harnesses and the antennae plug into the HU and then plugged them both into the factory harnesses. The HU powers up loads and ejectes CD's fine but for some reason no sound is coming out at all. I have a g35 Coupe w/BOSE. Any help is appreciated.
Old Nov 10, 2006 | 08:30 PM
PDX_Racer's Avatar
PDX_Racer
You need to either bypass the BOSE amps, or provide power to them through the harness.
Old Nov 10, 2006 | 09:27 PM
jakesford's Avatar
jakesford
yeah I'm guessing the remote turn-on isn't hooked up... Two things that people miss:
Amp remote turn on
Power antenna connection
Old Nov 11, 2006 | 05:45 AM
hiimwayne's Avatar
hiimwayne
Newbie
Now how would I attempt to do this? This is my first time doing this so should to be a little specific. Or should I just bring it in to an audio shop? Thanks again guys
Old Nov 11, 2006 | 05:57 AM
first350's Avatar
first350
do you have any of the wiring diagrams that would have come with the HU and warnesses? Those diagrams will tell you which wire colors do what. If you don't have them, try searching online for it.
-Peter
*I just installed my HU and used the Metra harness - if you have the same one, I could find the correct color wire that's for the 'remote turn on' / 'power antenna' (this wrie goes from the HU to the amp...when the HU turns on, it sends a signal to the Amp telling it to also turn on - if you don't have the wire connected properly, the amp will never turn on)
Old Nov 11, 2006 | 06:00 AM
mario23's Avatar
mario23
The manual for the ddx is available from kenwood. Its pretty straight forward.
As far as the bose stuff...i can't help there. Mine didn't have any of that. Hopefully someone here can help you with that. You know to ground the e brake wire instead of attaching to the e brake for viewing?
Old Nov 11, 2006 | 06:10 AM
Voboy's Avatar
Voboy
What car was this orginally for? I'm not sure if it matters but don't you need to buy some other kinda wiring if you have bose?
Old Nov 11, 2006 | 05:12 PM
hiimwayne's Avatar
hiimwayne
Newbie
Thanks for the help guys. It wasn't the problem with the wiring. Found out I needed to bypass the Bose HU and so got a PAC ROEM-NIS2. Now how do I ground the wire so I can watch Movies. I have a g35 automatic.
Old Nov 11, 2006 | 05:32 PM
mario23's Avatar
mario23
I grounded mine to the front seat mount bolt.
I just ran the wire down from the console under the carpet to the seat rail and bolted it down.
Old Nov 11, 2006 | 06:21 PM
Voboy's Avatar
Voboy
parking brake wire ground by wiring to the harness... wire should usually be black.
This is what I did with my ddx7017 and it works.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
