Woofer Install-Need Advise!!!
Old Nov 15, 2006 | 08:59 AM
Mr. Famouz's Avatar
Mr. Famouz
Default Woofer Install-Need Advise!!!
I just installed the Eclipse AVN-5435 in my 06 Z, (WHICH FIT LIKE A GLOVE!). I installed the amp under the passenger seat, and the 10" Eclipse Woofer in the factory "woofer hole". It sounds like **** because of the aluminum housing. Here's where my question starts: Someone told me I can remove that aluminum housing and fit a custom box in that enclosure, has anyone done that? Or should I make a custom wood panel to go over the woofer and dynamat the inside of the enclosure? PLEASE HELP!!
Old Nov 15, 2006 | 09:01 AM
savvy's Avatar
savvy
Nazar from wickedcas makes a custom sub box that goes in the cubby behind the seat. www.wickedcas.com
Old Nov 15, 2006 | 10:49 AM
12AutoX's Avatar
12AutoX
I debated putting a sub in the factory spot for a while and couldn't come up with a workable solution. I ended up putting the amps there instead, as so many others have. The problem is that there is too much room back there to make the whole area a "sealed" enclosure, not to mention how hard it would be to seal. A 10" sub generally needs .75-1.0 cubic feet of tightly sealed enclosure. It's not impossible, but putting one there would be like building a ship in a bottle. There are more practical solutions. I had a JL Stealthbox, but it was too much bass for the car for my listening style. I built this instead:
It's an 8" Polk MOMO. Small, but good enough for me. My woofers in the doors carry most of my bass. There are a lot of cool options out there. The factory sub is a free-air unit. I never really cared for them, but Nissan seems to fancy them. Bottom line, you can find a better solution.
Old Nov 15, 2006 | 01:52 PM
nothix's Avatar
nothix
i had no luck finding the mentioned sub box on www.wickedcas.com
I'm considering the sub install in the factory slot, and was wondering on you feeling about it after having done it. Should I just spend $100-150 and get a box? I'm worried about losing half of my trunk space.
THanks
Old Nov 15, 2006 | 01:54 PM
z350boy's Avatar
z350boy
THanks
They are there. if you don't see them call. I don't have this unit but word is Nazar is one of the best. put it this way...I was heading up to his shop FROM NEW YORK!!!
Old Nov 15, 2006 | 10:29 PM
redcrxsi's Avatar
redcrxsi
THanks
Here ya go
http://www.wickedcas.com/store/produ...fb0be683958663
Old Nov 15, 2006 | 10:43 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
ditto on getting nazars box if you dont want to loose any trunk space, nor spare tire, and want the best possible sound in the stock location, this is the way to go
b
Old Nov 18, 2006 | 01:23 AM
350z4realz's Avatar
350z4realz
I installed a 10" autotek sub in the stock location and had the same problem. What I did was tried my best to seal up all the holes with silicon and tape as much as possible (doesn't have to be perfect) and stuffed three pillows inside to take up space and somewhat seal up the area and create a smaller enclosure sort of. I ended up with about one cubic feet of air space and the sub sq sounds great to for my needs. It hit the mid bass notes and also the lows. I might stuff another one to bring the air space even lower to see what that would do to the sq. Hope this helps.
Old Nov 20, 2006 | 01:28 PM
Mr. Famouz's Avatar
Mr. Famouz
Yea I heard about doing that with the pillow stuffing.
Vigman
Nov 17, 2015 04:34 AM
codek
Sep 27, 2015 03:21 PM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
alphared
Mar 10, 2003 11:51 AM
