New system goin in, need input!
I am upgrading the stock non-bose system in my car out of necessity cuz it sucks. I want to list the stuff i already have, and plan to get, then see if there is anything i missed or that will make the system better. Any input is appreciated.
have:
-Clarion Max675VD w/wire harness
-Boston Acoustic Pro 6 1/2in. components
-Infinity Kappa prefect 10in. sub
-Clarion Ipod Cable
-Alpine MRD-M605 amp for sub
-Z enclosure under strutbar
-Metra 06' Double din dash kit
-Zenclosures 1" speaker spacer
need:
-Alpine MRV-F545 amp for components
-Optima yellowtop
undecided:
-Clarion 975 nav?
-Cap?
the total watts for this system are going to be around 900 rms, between both amps and spkrs and sub. Is that enough to warrant a yellowtop and cap, or one or the other. Any advice is appreciated
have:
-Clarion Ipod Cable
need:
-Optima yellowtop
undecided:
-Clarion 975 nav?
-Cap?
Budget yourself about $100 for the power hardware:
Battery Tap
Battery Fuse
Heavy Guage Cable (+) & (-)
Second Fuse Box/ +12 VDC Distribution Point
Ground Distribution Point
Acoustic poly-wool for inside your speaker box.
Speaker grill
1" front door spacer
Battery Tap
Battery Fuse
Speaker grill
Battery Tap
Battery Fuse
Speaker grill
Battery Tap
Battery Fuse
Speaker grill
Originally Posted by 05-Z
Having one 4 channel amp would make your life easier....trust me! Just an idea, and it's cheaper.
I would go with the under strut box.
Mike (Zenclosures) sells the front speaker_spacers
I just installed a set of speakers using his spacers - worked perfect.
-Peter
-Peter
Originally Posted by Stanky19
I thought about that, but i would then be running the components and the sub off of a 4 channel amp. is that possible, i was told i couldnt do that, but logically it would make sense that the sub would tak 2 channels and leave 2 free for the components.
Yeah, the shop will take care of all the wires and fuses you will need at ridiculous prices. You'll probably be paying about $250 for all of the stuff from them.
Order everything you need online and take it some where if you need it installed. I recomend putting the sub in the box and position it before you take it in or they will probably charge you about $50 for sub box install. The head unit isn't too hard and they probably will charge around $100 for that.
Save some money and do the install yourself or at least some of it.
Justin100
Nov 29, 2015 03:58 PM
