Popping fuses, need another power source
Old Mar 26, 2003 | 05:51 PM
wadd3456's Avatar
wadd3456
Default Popping fuses, need another power source
Well ive officially over loaded this circuit haha.
The 12v switched power feed running the headunit is split to the dvd player, amp, headunit controller , tv booster and (then I attemped to hook it to the antena booster).
It runs for about 5 min then pops the "power mirror" fuse under the dash. What the heck is that fuse running those parts for?!
Regardless, where can I get another 12v switched supply to run my antenna booster?
Thanks
Scott
Old Mar 26, 2003 | 06:43 PM
ares's Avatar
ares
Veteran
Id say a dedicated power line to a aftermarket fuse box... I used stock wiring in my last car, hooked up an air horn, and blew my parking lights whenever I used my horn, not cool.
now in this car, I have run a 6gauge wire into the car and will power anything I need off of this. its straight to the battery, with its own fuse. not piggybacking off anything else.
Old Mar 27, 2003 | 03:20 AM
wadd3456's Avatar
wadd3456
True, but i need a switchable 12v (only turns on when the car is on). Where can I run that from?
Old Mar 27, 2003 | 04:44 AM
AndyB's Avatar
AndyB
Default Best bet
Your best bet is to run a dedicated power line from the battery. If you want it switched you can use a relay driven off of your current power tap to turn on the big wire.
Just my $0.02
Old Mar 27, 2003 | 05:19 AM
Mikey Likes It's Avatar
Mikey Likes It
Charter Member #44
In the fusebox, behind the panel, is a breakdown of which is switched 12V and which is not. Try another tap from there...
Old Mar 27, 2003 | 05:47 AM
tlsimon's Avatar
tlsimon
Default power source
I power my dvd player and monitor with the cigratte lighter i tapped into and its is perfect turns on when i turn on the key.
Old Mar 27, 2003 | 08:09 AM
wadd3456's Avatar
wadd3456
Yeah I guess I could use the Cig lighter. I have the radar detector running off it now. Hopefully it doenst pop that too!
Old Mar 27, 2003 | 09:14 AM
ares's Avatar
ares
Veteran
you are probably best using the relay idea then, itll let you turn it on and off when the car is on and off. and wont blow any fuses.
tap into whatever you want, but I dont think your gonna find a line with more than MAYBE 30amp fuse. which very likely isnt high enough for a strong system.
Old Mar 27, 2003 | 09:44 AM
abz123's Avatar
abz123
Might want to put the amp on it's separate line.
Don't think the other stuff pulls as much power.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
lapham3
Oct 7, 2022 03:15 PM
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
