Grounding ok?
Old Mar 12, 2007 | 12:20 PM
Crom's Avatar
Crom
Default Grounding ok?
I got 0awg for power to distro block.
4awg power from distro to 2amps and cap.
4awg grounds from 2 amps and cap to distro block.
0awg from ground distro block to chassis....this allright?
Thanks...
Old Mar 12, 2007 | 12:40 PM
StreetOC192's Avatar
StreetOC192
sounds good
Old Mar 12, 2007 | 12:42 PM
Crom's Avatar
Crom
sweet....
Old Mar 12, 2007 | 06:04 PM
C Dubs's Avatar
C Dubs
Your grounds should always be the same AWG as you leads. Like I posted for another member, you wasted some money on the 0 AWG wire, because the current drops once you switched to 4. It will work, but just a little knowledge for next time. What components are you going to use (amps,speakers,etc?)
Old Mar 12, 2007 | 06:14 PM
Crom's Avatar
Crom
polk mmc6500, 2 jlw6v2, ED nine.1 at 1ohm, ED nine.2, 1 farad cap. a couple of my buddys mouths dropped when they saw the size of that cable...I realize now I def could have down-scaled...there's no way I'm re-theading that power though...
Old Mar 13, 2007 | 04:09 AM
C Dubs's Avatar
C Dubs
Yea I had 0 AWG in my last car, and have a spool waiting for when I finally put a system in my Z. Atleast you know youll never starve your amps of power. Make sure you post pics after the install.
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
