Use NAV while driving
Old Apr 14, 2003 | 08:15 AM
HonicZ's Avatar
HonicZ
Question Use NAV while driving
I wanted to find out if anyone out there has found out how to disable the feature that doesn't allow most of the Nav features to be used while driving. A friend of mine said that with most of the nav systems he has seen, this feature can usually be disabled by finding the cable that leads from the Nav to the engine compartment, and disabling it. I haven't looked into it yet, but I wanted to see if there is a known solution for this.
And to jump ahead of the safety-freaks out there who will give me static about tampering with the nav and causing unsafe driving conditions and all that jazz, when I'm driving the Z, about 90 percent of the time I have a co-pilot with me and it's a pain in the a$$ to stop every time she wants to make a change on the system.
Thanks in advance,
H
Old Apr 16, 2005 | 02:26 PM
InternetABYSS's Avatar
InternetABYSS
wish there was a fix for this
Old Apr 16, 2005 | 08:05 PM
Teez Zee's Avatar
Teez Zee
search generatorlabs.com
generator has fix for this and several other problems
Old Apr 16, 2005 | 08:19 PM
KPierson's Avatar
KPierson
This is an easy fix, and should be all over the boards.
All you have to do is place a switch inline with the vehicle speed sensor wire. However, this will mess up all your record keeping.
It would probably be easier and better to just replace the 'co pilot' with a less controlling model.
Old Apr 16, 2005 | 08:21 PM
zand02max's Avatar
zand02max
Thanks in advance,
H
Me as well, wish it was voice activated as in the Pioneer AVIC-N1, such a PITA too pull over to plug something in especially when you have a passenger!
Old Apr 16, 2005 | 08:35 PM
mucky's Avatar
mucky
With my alpine nav system I grounded the wire that is supposed to be attached to the parking brake. This fools the nav system by thinking the brake is always on, thus the use of all features while driving.
Matt
Old Apr 16, 2005 | 08:37 PM
zand02max's Avatar
zand02max
Matt
I thought that was just for the DVD movies to play while driving?
Old Apr 17, 2005 | 05:49 AM
mucky's Avatar
mucky
On my DVD player there are no wires for this, just the basic ones. The parking brake wire is on the Nav wire harness.
I'm not sure if you guys have the factory nav or aftermarket. If it's aftermarket, you should be able to find the wire in the instruction booklet and be able to ground the wire yourself. If you have the factory nav, i have the service manual and can try to find if there is a wire that hooks into the parking brake.
Matt
Old Apr 17, 2005 | 03:11 PM
InternetABYSS
I looked and there is nothing....generatorlabs is a dead site.
Old Apr 17, 2005 | 06:00 PM
Teez Zee's Avatar
Teez Zee
http://www.generatorlabs.com/
Welcome to GeneratorLabs
Home of the NavBox
Home of the NoNag
DVD movies, video games and MP3's with visualization can now be dsiplayed on your factory Navigation Screen with the installation of the NavBox. See product page for more info and a demonstration.
Tired of that annoying disclaimer screen that comes up on your Nissan navigation screen? The No-Nag will make your navigation experience so much more pleasant. See product page for more info.
Old Dec 20, 2005 | 11:37 PM
sexi z's Avatar
sexi z
So Has Anyone Used This?
Does It Work?
Any Problems?
Old Dec 21, 2005 | 09:53 AM
Beaker02's Avatar
Beaker02
Does not look like it's a cure for the thread. FYI.
Old Dec 21, 2005 | 09:57 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Out of business at least since June.
At this time I will no longer be accepting orders. I thank you for your support in the past and continued support in the future. I will be relocating GeneratorLabs to another state. In the massive amount of confusion that accompanies moving an entire home, lab and family to a new home I am afraid that I will not be able to support any new sales. I will continue to respond to emails and offer tech support to existing customers. I will fulfill all orders recieved as of 6/17/05
Old Dec 21, 2005 | 02:37 PM
james840a's Avatar
james840a
Matt
Mine is connected to the parking brake wire of my iva-d310 witch is connected to a switch to ground. Works great for my nav and dvd
Old Dec 21, 2005 | 03:29 PM
KPierson's Avatar
KPierson
For a bypass to the Nav OK disclaimer check out www.KPtechnologies.com
KPtechnologies just rereleased the Nav OK bypass, the new version has a user adjustable delay. Once this module is installed its possible (with extra parts) to use the 'OK' button to allow for Navi input while driving. You basically use the 'OK' wire that is installed during the Nav 'OK' bypass module installation to trigger a time delay relay which will activate a relay that will break the VSS wire going to the Navi unit.
Of course, I don't recomend breaking the VSS wire for several reasons.
1. Unsafe
2. Inaccurate maitenance records
3. Inaccurate MPG readings
4. Inaccurate movement while VSS is detached
Old Dec 31, 2005 | 12:59 PM
trdsupratt94's Avatar
trdsupratt94
You know what's funny is that mine allows me to make changes while driving. I know that when I first got the car it would not but now for some reason it will, I am not sure what I did to allow this.
Old May 9, 2006 | 10:28 AM
z350boy's Avatar
z350boy
UH UH...I checked the site and they have a couple of interesting devices!!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
