Is it possible for a Aftermarket Navigation mount it in factory navigation dock
Old Apr 4, 2007 | 06:41 PM
Tinghei's Avatar
Tinghei
Default Is it possible for a Aftermarket Navigation mount it in factory navigation dock
I had a Pioneer AVIC-Z1 ever since last year and i finally realize it i still have not install it into my Z yet. I would like to ask can i customize the compartment where the original factory navigation is puted so the aftermarket navi can be a perfect fit. I would like the door still be working too..... I dont know if yor can understand but i just want to give it a shot.
Old Apr 4, 2007 | 06:55 PM
THE TECH's Avatar
THE TECH
More than likely not. The upper compartment is too small for the rear of the unit to fit there.
Old Apr 4, 2007 | 07:44 PM
Fletch69z's Avatar
Fletch69z
Yes, it is possible for aftermarket DVD Nav to go in the stock spot. It just depends on which one you pick, . Go to Crutchfield.com and see what will fit in the Z.
Old Apr 4, 2007 | 07:54 PM
THE TECH's Avatar
THE TECH
If you're just talking about a Garmin or similiar unit, then there would be no issue. I had a Garmin Nuvi 660 as well as a Garmin Street Pilot in the cubby spot. Either will work fine there, but you will want to get the external antenna.
Old Apr 5, 2007 | 04:52 PM
Spike100's Avatar
Spike100
I'm not sure you received a clear answer to your question.
You will not be able to fit the Pioneer AVIC-Z1 into the upper/forward cubby (where Nissan places the OEM navigation unit). If you install the Pioneer AVIC-Z1, you must remove the factory H/U, and put the Pioneer AVIC-Z1 into the double-din space.
--Spike
Old Apr 18, 2007 | 06:10 PM
Tinghei's Avatar
Tinghei
--Spike
thz spike........ my partner and i trying a different approach if is works out then i will post it up on here>..
Old Apr 18, 2007 | 08:47 PM
Spike100's Avatar
Spike100
I think I understand what you are planning since I tried doing this as well. The depth of the forward/upper cubby is inadequate to accomodate the the Pioneer AVIC-Z1. To overcome this problem, you must fabricate a new center console replacing the stock dash piece. That would have been the best way for Nissan to do this (placing the double-din slot higher on the dash), but they wanted to use the upper/cubby slot for the navigation screen (which is the best position for safely viewing a navigation device).
Your plan is wise since you want the double-din position higher on the dash where it should be for easier and safer operation.
--Spike
350z82
Oct 1, 2015 06:25 PM
