07 Stock Alarm Mod
Old May 17, 2007 | 07:38 AM
edchoy02's Avatar
edchoy02
Default 07 Stock Alarm Mod
I've tried method of push the two buttons on the alarm remote to disable the "honk" that sounds when the stock alarm is activated but it did not work on my 07 Z.
Has anyone been able to disable the "honk" on an 07? If so how?
Old May 17, 2007 | 07:39 AM
Richy350Z's Avatar
Richy350Z
Isn't it the red buttom on the bottom of the remote?
Same as all other Z's ?
Old May 17, 2007 | 01:15 PM
edchoy02's Avatar
edchoy02
The red button is the panic button. When you press it the horn keepson honking.
I am try to NOT disable that single horn honk that happens when I activate the alarm.
Old May 17, 2007 | 02:15 PM
Voboy's Avatar
Voboy
Hold the lock button til the emergency lights flash. Hit lock, no honk.
Old May 17, 2007 | 04:11 PM
edchoy02's Avatar
edchoy02
I am going to try that as soon as I go outside to my car!
Old May 17, 2007 | 04:46 PM
BabyZiLLa's Avatar
BabyZiLLa
I didn't know it was possible. Just did it on my 06'. Worked great.
Old May 17, 2007 | 04:52 PM
creationv2's Avatar
creationv2
what? if you hold the lock button then itll honk....and honk again when you well hit it again? am i missing soemthing?
Old May 17, 2007 | 07:03 PM
usmanasif's Avatar
usmanasif
Read your car's manual. It will make sense.
Old May 17, 2007 | 07:15 PM
edchoy02's Avatar
edchoy02
ok, I got it. Reading the manual does not work for 07 Z because it is not in the manual. The way to do it is:
1. Hold down the the lock button on the alarm remote.
2. While holding down the lock button hold down the unlock button
3. Keep holding both buttons till your tail lights flash.
Done!
If you have problems try holding the lock button in step 1 for maybe 15 secs before holding down the unlock button.
Cool now I can set my alarm in my car without drawing attention. Downside is if you use your alarm to find your car in a parking lot you will have to look for the lights flash instead of listening for the alarm.
Drive safe.
Old May 17, 2007 | 07:35 PM
usmanasif's Avatar
usmanasif
$100 says it is on page 3-7 of the 2007 Z's manual under "Setting Hazard Indicator and Horn Mode". Get back to me on that.
The procedure is 100% same as in '03-'06 Zs. What you listed above is correct, but pressing and holding the two buttons "simultaneously" will yield the same result.
Old May 17, 2007 | 08:09 PM
creationv2's Avatar
creationv2
man i never knew this...just did it...and man thats just sick! no more people looking at me when i locks the z!
Old May 17, 2007 | 10:24 PM
Zerocool's Avatar
Zerocool
I was wondering how to get rid of the honk when I lock it (Didn't read the manual that well!)
Thanks
Done!
Drive safe.
You can use the panic button if looking for your car.
Old May 17, 2007 | 11:33 PM
Voboy's Avatar
Voboy
You're reading my post wrong Hold lock til emergency lights come on. Then (to test...) hit lock, and it won't honk.
Old May 18, 2007 | 10:09 AM
umsta's Avatar
umsta
wow thx guys
Old May 29, 2007 | 10:42 PM
L33TZOR's Avatar
L33TZOR
ok i tried this. my stock alarm is modded so that the blinking LED is also audible with a small piezo horn, kind of like a heartbeat.
everyone usually asks what the noise is at meets when i got the lambos open.
when my car arms itself notice that the led will remain steady for like 4 seconds. this is found out after i did the piezo on the led lead.
Old May 29, 2007 | 10:48 PM
redman333's Avatar
redman333
Wow, I've had my Z for awhile now and have been on this site for awhile. Thought I knew everything about the car but didn't know this.
Old Oct 17, 2014 | 01:52 PM
andyzgirl's Avatar
andyzgirl
Newbie
How do I disable the stock alarm? I have a viper alarm and suddenly both alarms are arming.
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
