wiring
Old Jul 12, 2007 | 07:07 PM
Mr_Kebo's Avatar
Mr_Kebo
Default wiring
This is my first headunit install. my buddy always installed them for me before. The only 2 wires i have left are one that says Car speed signal input and another that says reverse gear signal input. Where should i hook these wires to. Also another long light green wire that says to connect it to the parking brak power supply.
Old Jul 12, 2007 | 07:27 PM
mrspradlin's Avatar
mrspradlin
need to know what you are installing.
are you using a wire harness adapter?
Old Jul 12, 2007 | 07:41 PM
Mr_Kebo's Avatar
Mr_Kebo
its a AVIC-D2 and yes i have the wirine harness adapters that plug into the factory wiring.
Old Jul 13, 2007 | 04:48 AM
Lsmith9523's Avatar
Lsmith9523
Sounds like the wires for the Nav feature. Your speed wire is located in the harness found behind white box below your headunit. I think most people tap the reverse wire, on the side quarter panel behind seat on drivers side. I remember reading several threads on connecting these two wires. If I had time to located them for you, I would, but I am at work. I am sure you tried to search for them,,,but try searching under speed pulse wire,,,,and reverse signal wire. I hope you find something to help,,,good luck and keep us posted.
Old Jul 13, 2007 | 07:17 AM
Mr_Kebo's Avatar
Mr_Kebo
yea i searched but it was late. im goin to try again today. thx
Old Jul 13, 2007 | 07:36 AM
Mr_Kebo's Avatar
Mr_Kebo
is www.avic411.com down. it wont load for me at home?
Old Jul 13, 2007 | 01:09 PM
5ZVP's Avatar
5ZVP
Do what I would do when I build something and have screws left over...
shrug and figure I didn't needed it any way [
Old Jul 13, 2007 | 02:49 PM
Mr_Kebo's Avatar
Mr_Kebo
Well i know i need the reverse wire so and the vss wire. I need to know where to connect the light green wire to the parking brake power supply.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
