IDMAX 10 d4 with Zenclosure box?
Old Aug 12, 2007 | 07:18 PM
Carter05's Avatar
Carter05
Default IDMAX 10 d4 with Zenclosure box?
The ID website says these require a 9.6 inch mounting diameter, but the zenclosure under strut box will only accomodate a 9.25 hole.
Anyone have any success using this box for these subs, and if so what did you do to make it work? OR is it not feasible to do that way?
Old Aug 13, 2007 | 06:42 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Maybe Zenclosure could make you a custom box?
Old Aug 13, 2007 | 07:25 AM
StreetOC192's Avatar
StreetOC192
I would think if you called and talked to them, they could cut the mounting hole to the diameter you need....HOWEVER, the mounting depth of the IDMax is 7.625" and the recommended maximum mounting depth by Zenclosures is no more than 7". I think that might be a problem.
Old Aug 13, 2007 | 07:31 AM
davidc81's Avatar
davidc81
you could probably fab a 3/4" mdf spacer to attach to the box that would allow for the extra depth clearance as well as a larger mounting diameter
Old Aug 13, 2007 | 07:50 PM
Carter05's Avatar
Carter05
The spacer is kind of what I think I will have to do. Hopefully I can get that to work. Might look a little tacky, but hey it's the price for nice bass!
Old Aug 14, 2007 | 02:26 AM
doug's Avatar
doug
i took a dremell to my box
Old Aug 14, 2007 | 04:15 AM
StreetOC192
I think asking Mike at Zenclosures to cnc cut the hole the size you need would be the cleanest and easiest way for you.
As for the depth, instead of just a spacer ring, what about cutting out a whole new front panel out of 3/4" mdf and glue/screw to the Zenclosures box, then cover in black carpet.....this way it might not look as 'tacky' as you put it.
Old Aug 14, 2007 | 04:39 AM
350zspl's Avatar
350zspl
spacer will work
better to fab a complete new baffle either 5/8 or 3/4 mdf
and double baffle the enclosure
allowing for a better look than spacer
more rigid baffle
solving mouting depth and diameter issue
Old Aug 14, 2007 | 09:56 PM
Carter05's Avatar
Carter05
Thanks for input guys. Really appreciated!
BlueSQ
Feb 24, 2012 05:02 AM
BlueSQ
Apr 27, 2011 01:21 PM
16psibrick
Audio Builds
Jun 23, 2008 02:30 PM
AParshall04
Feb 20, 2006 11:49 AM
