Garmin in cubbyhole question
Old Sep 13, 2007 | 07:49 AM
DrDave83's Avatar
DrDave83
Default Garmin in cubbyhole question
quick question, with the garmin set up in the cubbyhole will i need to run an antenna for it? I'm guessing it won't be able to pick up signals through its internal antenna since it would be shielded.... anyone have any experience with this?
Old Sep 13, 2007 | 12:14 PM
Get_Zwole's Avatar
Get_Zwole
no it will work fine through the plastic. I had mine in there for a montyh or so never lost signal at all.
Old Sep 13, 2007 | 04:40 PM
Spike100's Avatar
Spike100
If you’re asking about mounting a Garmin portable inside the upper/forward cubby, you probably do not need an external antenna. I’ve put a Garmin V (an old unit) and a Nuvi in the upper/forward cubby, and did not need an external antenna. The unit’s internal antenna worked fine.
--Spike
Old Sep 14, 2007 | 12:31 PM
realcom2's Avatar
realcom2
i use my tom tom in the cubby with no problems
Old Sep 14, 2007 | 05:54 PM
PDX_Racer's Avatar
PDX_Racer
+1
Old Sep 14, 2007 | 06:39 PM
kdogg24's Avatar
kdogg24
I ran mine through the plastic just fine....then I installed XM into my car and drilled the corner of the cubby to run wires...it wasn't hard to do, and i don't regret it...yet (been done for 7 months now) :-D
Old Sep 26, 2007 | 04:08 AM
wolfb21's Avatar
wolfb21
sorry to leech onto someone else's thread but to those that ran a garmin in the cubby hole, which model did you use? thanks
Old Sep 26, 2007 | 04:23 AM
Get_Zwole's Avatar
Get_Zwole
nuvi 680 is the one i got its for sale too
Old Sep 26, 2007 | 07:46 AM
dmw5678's Avatar
dmw5678
680 fits with room to spare. However, FM broadcast for the 680 suffers a little. Navigation is fine
Old Sep 26, 2007 | 07:51 AM
iStan's Avatar
iStan
ZR
+1
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
