TV Display for 350z, suggestion?
Old May 25, 2003 | 01:08 AM
kelvin1704's Avatar
kelvin1704
Default TV Display for 350z, suggestion?
Can you post your TV display? what brand?
In malaysia, it comes without display... therefore, i would have to buy it separately.. therefore, I would need advice on this. Thanks.
Old May 25, 2003 | 07:50 AM
ares's Avatar
ares
Veteran
xenarc or farenheit ~7" screens fit well.
both can be had with AV in, and I know atleast the xenarc can be had with AV in and VGA in.
as for how to get a TV signal into the car, I heard that serius will be broudcasting news shows in a few months, youll need a new reciever, but it would include the video feed.
other than that, donno how to get TV into the car, most with these screens hook them up to a DVD player,nav, or computer.
Old May 25, 2003 | 06:23 PM
kelvin1704's Avatar
kelvin1704
the recommendation that u make fits into the allocated slot which is the screen area or where?
can u show me the link?
Old May 25, 2003 | 06:57 PM
ray_7's Avatar
ray_7
https://my350z.com/forum/showthread....threadid=30536
That's the Farenheit screen. I also want to purchase one myself.
Old May 26, 2003 | 07:14 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Look Here too:
http://www.350zfrenzy.com/forum/show...&threadid=1403
Old May 28, 2003 | 09:47 AM
KJ-350's Avatar
KJ-350
the 7001 has the most viewing area when installed! The LCD seriously goes from corner to corner! It takes up the entire "hole" in the cubby when installed. some of the other, if not most are not close to that b/c of buttons, dials, inputs, etc are all on the face of them where as the 7001 has them on the rear. for the $$ and perfectly it fits hands down I say the 7001!!!
Old May 28, 2003 | 03:59 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The Xenarc goes "corner to corner" too. It's buttons are actually below the screen and when installed they are beneath the little plastic horizontal bar in the compartment so they don't take up any viewing area at all.
Old May 28, 2003 | 04:45 PM
KJ-350's Avatar
KJ-350
didnt know that! looks good!
Old May 28, 2003 | 07:00 PM
kelvin1704's Avatar
kelvin1704
thanks people.
When choosing an LCD screen, do i have to look at it resolution? Pixel? does it matter?
and the most of all, can it take weather punishment? I am in Malaysia, its pretty hot here through out the year.
Old May 28, 2003 | 07:08 PM
ZEXC-33's Avatar
ZEXC-33
just quickly......if the buttons on the screens (Farenheit and Xenarc) are underneath or behind the monitor, how do u access them??? And even if u use the remote instead, wheres the IR pick up?
Old May 28, 2003 | 07:49 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I just set mine and forget them. Once you get it set there hopefully won't be any need to do it again. If I had to, I would simply have to remove the horizontal bar (it is removed in the pic I posted above) and play with the buttons, so it would really only be a matter of taking out two screws and removing the bar.
The remote I have doesn't run the screen. It is an infrared mouse for the computer.
Old May 28, 2003 | 09:54 PM
kelvin1704's Avatar
kelvin1704
is it promp to heat problem?
Other than that, what input does it has? RCA cable? does it has a 15 pin RGB?
Old May 29, 2003 | 04:22 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
No heat problems at all. It is a VGA screen with the plug shown in this thread:
Old Jun 9, 2003 | 07:56 PM
SkyMan's Avatar
SkyMan
what's the quality difference(picture) between the farenheit and the xenarc?
Old Jun 9, 2003 | 08:31 PM
all_bark's Avatar
all_bark
I left the screws out! The bar snaps into place and there is really no need for the screws. When needed (I have used the buttons) the bar pops out fairly easy.
Old Jun 9, 2003 | 10:48 PM
kelvin1704's Avatar
kelvin1704
to be frank, i am still unsure about which screen to get.. sigh
Old Jun 10, 2003 | 10:17 PM
alphared's Avatar
alphared
The question is what application are you using it for???
If its just DVD then get the Farenheit and save your money. There is no need to get the VGA Xenarc just to watch DVD.
If its the VGA xenarc, then you're comparing TV to Computer screen. Higher resolution on the Xenarc.
Old Jun 10, 2003 | 10:46 PM
kelvin1704's Avatar
kelvin1704
definately VGA Xenarc then, can someone direct me to the a place i could buy it. thanks
Old Jun 11, 2003 | 02:30 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
You got it:
Xenarc Technologies
Old Jun 11, 2003 | 11:11 PM
kelvin1704's Avatar
kelvin1704
thanks for the link, but does this unit fit nicely in 350z compartment?
