Which Subs to get? alittle help.
Old Nov 2, 2007 | 08:29 AM
TBDesigns's Avatar
TBDesigns
Default Which Subs to get? alittle help.
Alright I'm running the Alpine w205 with a Alpine - V-Power 400W Class D Bridgeable Mono MOSFET Amplifier with Adjustable Crossover. And I'm adding a Zenclosure under the strut that holds 2 tens. which tens should I pick up?
1.) Alpine - 10" 500W Single-Voice-Coil 4-Ohm Subwoofer
2.) Infinity - 10" 250W Dual-Voice-Coil 8 Ohm Subwoofer
3.) Kenwood - 10" 300W Single-Voice-Coil 4-Ohm Subwoofer
4.) Pioneer - 10" 600W Single-Voice-Coil 4-Ohm Subwoofer
5.) Rockford Fosgate - Punch 10" 500W Dual-Voice-Coil 4-Ohm Subwoofer
6.) Sony - 10" 300W Single-Voice-Coil Subwoofer
Old Nov 2, 2007 | 08:36 AM
hoss4131's Avatar
hoss4131
first off, there is no such thing as a bridgeable mono block... the term mono means one, and you need 2 channels to bridge anything.
out of what you have listed, i would go with the alpines, based on your amps power output.
if you look at any other subs though, which i suggest, look for either single voice coil 2 ohm drivers, or dual 4 ohm coils,
Old Nov 2, 2007 | 09:33 AM
Tackett's Avatar
Tackett
is there a "none of the above" option?
And I dont think you can run a DVC sub in DVC mode with a monoblock. I may be mistaken on this though
Old Nov 2, 2007 | 09:35 AM
350zspl's Avatar
350zspl
i would run 2 each Revolution design audio classics
they will sound better
get deeper
get louder
than anything you mentioned
i can get you sick pricing on them as my friend owns the compnay
Classic Series Subwoofer
They were designed and built to be small sealed enclosure SQ subwoofers. When we tested them in small ported boxes we were extremely pleased. When tuned to the mid 30's they have a flat response. They are built off the same concept as the Alpha series. They offer a good amount of output with no distortion. The can accurately reproduce any bass note with ease regardless of what style of music you fancy.
Woofer Description
Vacuum formed polymica cone body with reinforced cone collar
Extended neck joints on cone, coil, and spider
Butyl rubber surround
Waterproof
Vented cone
2 inch long excursion voice coil
Rounded deep back plate
Low carbon front and back plate
Powerful dual stacked 55 oz magnets
Cast basket
Integrated tinsel leads
2.5" long excursion motor structure
Available in 15" built upon order
Box suggestions: Please contact us through email to get a box custom designed to meet your needs.
Port and driver already included-
Classic 10"
.75 ft3 sealed 1.0 ft3 sealed
1.5 ft3 with a 4" round or 12.5" slot port by 10.4" deep tuned at 44hz
2.0 ft3 with a 4" round or 12.5" slot port by 10.25" deep tuned at 37hz
Classic 12"
1.0 ft3 sealed 1.5 ft3 sealed
2.0 ft3 with a 4" round or 12.5" slot port by 12" deep tuned at 35hz
2.5 ft3 with a 20 square inch port by 16.33" deep tuned at 35hz *a lot less port noise
2.0 ft3 with a 20 square inch port by 12" deep tuned at 44hz * high output
Old Nov 2, 2007 | 09:36 AM
350zspl's Avatar
350zspl
none of the above is correct
you can use a monblock amp to run sub or subs
svc or dvc
Old Nov 2, 2007 | 09:40 AM
Tackett's Avatar
Tackett
I would get
http://www.woofersetc.com/index.cfm?...1C10FA3A03A188
there ya go
Old Nov 2, 2007 | 09:41 AM
Tackett's Avatar
Tackett
svc or dvc
educate me. how can you do this with only one channel?
Old Nov 2, 2007 | 09:54 AM
350zspl's Avatar
350zspl
mono block amp is 1 channel
lets say your using a box with one sub, and the box has 1 speaker input terminal,the sub is a svc , wire + & - speaker leads from amp output to enclosures speaker input terminal , than from enclosure terminal to - & + sub voice coil
lets say that you now bought a new sub for the same amp and same enclosure but the new sub is a DVC
process is run speaker - & + wire from mono amp speaker output terminal , to enclosures -&+ single terminal , than inside box you will take the single box terminal that has 1 male end + and 1 male end - and you will run 2 + wires off + terminal and 2 negative wires off - speaker box terminal , now hook up the 2 - speaker leads one to each - marked voice coil , and run the 2 + speaker leads one to each positive marked voice coil
Old Nov 2, 2007 | 11:24 AM
TBDesigns's Avatar
TBDesigns
Damn really didn't want to spend $200+ on one speaker. So none of the ones I listed will give me good bump?
Old Nov 2, 2007 | 11:41 AM
StreetOC192's Avatar
StreetOC192
For the budget conscious subwoofer shopper, I would recommend the eD 11Ov.2. $155 each. It will out perform any of the ones you listed IMO.
http://www.edesignaudio.com/edv2/pro...products_id=34
2 of these would work nicely in a Zenclosures box with about a pound of polyfil. With only 400 watts RMS they will be a hair under powered though.
If I were you, I would get 1 really nice 10" in a single Zenclosures box. I feel you will get better performance out of your 400 watts RMS. More info on your amp would help.......is it 400 watts rms at 4 ohm, 2 ohm, is it 2 ohm stable? how about 1 ohm stable?
Old Nov 2, 2007 | 11:52 AM
350zspl's Avatar
350zspl
well i can sell you RD for less than the $200 your speaking of
Old Nov 2, 2007 | 12:47 PM
TBDesigns's Avatar
TBDesigns
Damn don't know what to do now LOL.. Wanted to charge the woofers on my bestbuy card since i'm strapped right now.
Old Nov 2, 2007 | 06:37 PM
hoss4131's Avatar
hoss4131
i ALWAYS steer people away from eduh... they are a great company, if you are a sheep and bite into media hype.
they have been surrounded by some shady stuff as long as they have been around. including scams, lies, a rediculously high failure rate (still have a high failure rate with all their products...), and the rediculous things they claim in their online advertisemets
look around for some used stuff that is in good shape. are you set on two 10"s, or would you consider a single 10"? i have a diamond D6MKII that i could sell if you could go with a single 10".
Old Nov 2, 2007 | 07:02 PM
StreetOC192
I would be interested in hearing anything bad about Elemental Designs.....please post. I have never had/heard anything but good experiences.
Old Nov 2, 2007 | 07:07 PM
hoss4131's Avatar
hoss4131
they have almost a cult following of people that stick with them for the first few years after they hear about them, and a few people that swear by them, butif you stick around them long enough you will hear some stories...
there are several people who have bought into pre-sales from them who never recieved their product, or their money back. there is their failure rate which was up in the mid to high 60% for a while...
and their online advertisements are just laughable if you can pick up on their BS (which should be easy for most people), but some people still buy into it...
their products are definitly not the worst out there, but as a company they have a real bad rep IMHO. and that keeps me from doing any business with them. not to mention the fact that they still are far from the best bargain out there.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
