Speaker upgrade q's
Alright, please humor me. I did alot of searching but didn't seem to find many folks in my situation looking for what I'm seeking.
I currently have a AVIC-D3 installed with all the factory non-Bose speakers. I'm looking to upgrade the speakers seeking better highs and maybe a bit more bottom end, but not looking for major thump by any means. I think my days of subs and amps are over...just too much to deal with really.
Question #1: Is the AVIC-D3 powerful enough to run a set of ~$250 seperates? I understand I wouldn't be making the best use of them, but I'm looking for a noticeable difference from stock through a simple and fairly cheap upgrade.
Question #2: Is it worth keep the rears? I barely hear them now, but I wonder if adding a set of decent coaxials in the rear for a little more low end adjusting using the fader would work well?
Any help would be appreciated!
My opinion, replacing with comps up front,,,you will not gain much difference (w/o amp) than a decent set of coax. Most headunits will provide around 17-20 RMS.
As for the rear,,,different people here have different opinions. Me personally, I enjoy a slight rear fill. I replaced my factory non-bose with a set of coax and faded them greatly to the front.
as Lsmith says, dont waste your time running any thing other than a stock replacemtn coaxial with the headunit, any headunit, regardless or ratings, wont come anywhere close to making a decent set of speakres perform and sound right.
just get a 50-75 dollar stock replacement and pop them in your door...or spring for an amp and front speakres
b
b
I replaced my rears with coax's and did a heavy bias towards front on the fader. When I replaced my amps, I disconnected them and don't really miss them now. Pullig all the trim off was a bit of a chore, have to be careful to not break the fasteners, not much of a return IMO.
+1 on the amp + components answers. Don't bother without decent power. You could end up driving the HU amp into clipping and trashing your tweeters...
Originally Posted by doug
IMO the rear speakers on a Z are position poorly ... when i had my maxima they were in the rear deck.. and you could get true rear fill.... in the Z the speakers are sitting right behind your ears.. and to get a nice balance of rear fill to compliment your fronts.. you have to damn near turn the rear speakers till they arn't even really being used.. so really.. what the hell is the point?
--Spike
Originally Posted by 350zspl
headunits can run coaxils suffciently
headunits powering components sound horrible
A quality speaker (and that could be either a coaxial speaker or a component speaker) needs an amp capable of providing adequate power to produce good sound. It makes no difference if it’s a coaxial speaker or a component speaker. Either of these can produce great sound, but if either is a high-quality speaker, they need the extra power that an external amp provides.
--Spike
^^Good point. It’s not just the power (more amperage). A good amp delivers clean power that superior devices (e.g., coaxial, component speakers, SubW’s, etc.) need to deliver great sound. A low quality amp won’t help at all.
--Spike
--Spike
