amp question
Old Nov 14, 2007 | 02:33 PM
ni-z-mo's Avatar
ni-z-mo
Default amp question
I have an 07 base Z and I heard that there is a compartment where people put their amps so that you dont have to put it in the hatch area. Where is this compartment?
Thanks
Old Nov 14, 2007 | 04:18 PM
ni-z-mo's Avatar
ni-z-mo
Default amp
thanks
ni-z-mo's Avatar
ni-z-mo
Default amp
how do i run the wires up to my sub from there?
Old Nov 14, 2007 | 04:54 PM
350zspl's Avatar
350zspl
snake them down from glove and back thru metal shelf frame work to hatch
Old Nov 17, 2007 | 12:38 PM
lbz's Avatar
lbz
If you pull up the carpeting in the hatch area , you will see holes you can use to run speaker wire between your amp and your sub. I used some zip ties and anchors to keep the wires in place and provide a clean look.
Old Nov 17, 2007 | 12:45 PM
phreaktor's Avatar
phreaktor
Design Engineer
Good job helping out the new guy ppl. This is how it's supposed to be.
Old Nov 17, 2007 | 12:47 PM
UHATEIT's Avatar
UHATEIT
I would also suggest where the wires come through the metal holes to put some black tape (electrical tape) arounf the wiring at that spot so that the metal doesn't cut through the wiring covers and cause a ground out of the power. just my 2 cents
Old Nov 17, 2007 | 09:24 PM
350zspl's Avatar
350zspl
actually rubber or plastic gromments work better than tape
i use snap bushings
Old Nov 18, 2007 | 04:55 PM
ni-z-mo's Avatar
ni-z-mo
thanks...good lookin out cant wait to start
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
