What's the proper way to connect a 4 gauge wire to a spade connector?
Old Nov 20, 2007 | 03:35 PM
ckny's Avatar
ckny
Default What's the proper way to connect a 4 gauge wire to a spade connector?
Ok, may sound like a stupid question but I figured I'd ask the audio masters on this board.
I am running 4 gauge wire to my amps. I have 4 gauge spade connectors that should connect to the end of the wire and go into the amp. What's the right way to connect the wire to the connectors? The wire fits in it fine but how do I keep it from coming out? It seems like it would be tough to crimp it with pliers and it just seems too big to mess with solder (I'm not a soldering champ to begin with).
What's the right way to do this?
Thanks!!!
Old Nov 20, 2007 | 03:40 PM
doug's Avatar
doug
chrisssssssssssssssssssssssssssssyyyyyyyyyyyyyyyyyyy
Go to home depot.. get the yellow (i think) crimp that has a smaller head but will accomodate a 4 gauge wire...
Old Nov 20, 2007 | 03:49 PM
DHCrocks's Avatar
DHCrocks
put the connect on the ground, place a nail across the crimp portion and slam it with a hammer. That's the cheap ghetto way, it works perfectly fine and is perfect if you're only going to do a few. a impact crimper is around $45 for large gauge terminals. They both work on the same principle.
Old Nov 20, 2007 | 04:01 PM
Ge|atinousFury's Avatar
Ge|atinousFury
Go to www.weldingsupply.com and search for "840L" in the search box. It wll take you to the Lenco Swedge-On Tool Model 840l. I just used it for crimping ring terminals onto 0awg wire and it worked PERFECTLY. 3 hits with a 2 lb. hammer and it was good to go. At $8.24 plus shipping you can't go wrong.
Old Nov 20, 2007 | 04:31 PM
Sean's Avatar
Sean
vise grips help, first set it to crush just a little, than keep adjusting it tighter each crush for about 3 squeezes. When you are done it will be tight as a nuns anus.
Old Nov 20, 2007 | 05:06 PM
ckny's Avatar
ckny
Haha, what's up Doug. Long time! I'm still using those kickers.
Thanks for the suggestions everyone. I'm gonna redo the wires on friday after I install my project mu pads!
Old Nov 20, 2007 | 10:50 PM
1sentra's Avatar
1sentra
you need the right sized crimpers man. ive seen those suckers get as big as bolt cutters.
Old Nov 21, 2007 | 06:52 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Vice grips, a hammer or a vice. No need to get fancy.
Old Nov 21, 2007 | 09:20 AM
james840a's Avatar
james840a
Thanks!!!
For 4gauge wire, you shouldnt be using a spade connector. That large of wire the amp should have a terminal for Power and ground to accommedate that large size . Im assumming that you are talking about the power and not speakers. If your amp have a screw type terminal that uses a spade connector most likely it is for 8 gauge and small wire.
You have a picture of these amps? it sure would help use to help you
Heres a image for what im talking about, see number 1
Old Nov 21, 2007 | 10:10 AM
doug's Avatar
doug
its an old school kicker amp.. i should know.. i bought them
it has a screw and a flat metal with a hole in it.. that when you screw it.. the metal lifts up..
Old Nov 21, 2007 | 10:19 AM
james840a's Avatar
james840a
Oh well in that case, what i do is use a center punch and hammer in a dent to hold in the wire in the connector. Or fine a commercail electrican that has a big gauge cripper.
Old Nov 23, 2007 | 05:32 PM
Ichigo's Avatar
Ichigo
Here's a ratcheting crimper I ordered for X-mas
http://www.partsexpress.com/pe/showd...number=360-646
Does 8-2 AWG wire
Old Nov 23, 2007 | 06:15 PM
Mike Wazowski's Avatar
Mike Wazowski
Does 8-2 AWG wire
nice find, I just ordered one also
Old Nov 23, 2007 | 07:35 PM
Ichigo's Avatar
Ichigo
Got one of these also:
http://www.partsexpress.com/pe/showd...number=360-624
Tired of taking 4 snips out of a 4AWG wire
Sears also has a rockin 35 LED rechargeable Shop light
http://www.sears.com/shc/s/p_10153_1...me=Work+Lights
15 bucks!
Sorry to OT
Old Nov 25, 2007 | 06:47 AM
KPierson's Avatar
KPierson
I always used a bench mounted vice to crimp them. The only drawback is that it requires planning ahead because you can't really use a bench mounted vice when the wires are already in the car!
If that didn't work, and I was desperate, my Dad is an electrician and has some huge crimping tools.
Old Nov 26, 2007 | 03:37 PM
ckny's Avatar
ckny
thanks for the info guys. i didn't get a chance to do it on Friday but looking forward to it Sunday. I have the wires available to pull out and crimp but currently no bench vice. I will use the old hammer.
As for the amp, as Doug described, it has a screw that you pretty much need to stick a spade connector in. I assumed it was better to use 4 gauge since I had it already rather then 8. Doesn't hurt right?
Pleask
Dec 21, 2021 03:17 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
